Post by RedAndBlack on Jan 31, 2022 23:11:34 GMT -7
Research block off plates. They should fix most of your deacceleration popping
Post by willl84 on Feb 1, 2022 6:35:03 GMT -7
Research block off plates. They should fix most of your deacceleration popping This. Block off plates will take care of it. Also an ECU flash will too as most tuners disable the system entirely.
kaotico
Post by kaotico on Feb 1, 2022 22:02:31 GMT -7
Research block off plates. They should fix most of your deacceleration popping This. Block off plates will take care of it. Also an ECU flash will too as most tuners disable the system entirely. Thank you.
My problem is:
which connector to solder?
kaotico
Post by kaotico on Feb 1, 2022 22:06:25 GMT -7
it´s done. Thank You
