silvertiger0015
Post by silvertiger0015 on Jan 2, 2022 8:06:36 GMT -7
Finally got around to install the blueskysea front and back camera. It works great so far and fits well in the front. I would recommend it. It always records soon as you turn the key and it does up to 5min loop video with impact detection that locks the video so it couldn't be saved over. All accessed on wifi no wires. The back i might have to mod out the center taillight bracket for more symmetry
silvertiger0015
Post by silvertiger0015 on Jan 2, 2022 8:07:24 GMT -7
I installed this during Sparkplug replacement. You need the airbox out to do it right. I then routed the wire to the front by fishing through the left channel that the wire loom feeds through to the headlight assembly. Also i had previously replaced the cigarette lighter outlet with a USB fast charging outlet. The camera system. Requires two hots. One directly to the battery. The other needs a hot that turns on with the key. So I ran an additional wire when running camera wire to the cigarette accessory hot. It isn't that hard to do. Only cut i had to make was to the camera mount in front on both tabs to get it to fit where I put it. Is made out of abs plastic so a small hacksaw was fine. The brain for the system fits pretty damn tight but well right below the exhaust servo. It all fits very well. If you are a non novice this could look extremely professional install. I might take pics of mine
