beefytom
Post by beefytom on Dec 4, 2021 19:22:43 GMT -7
So on my 2018 MT-10 I was getting an intermittent issue where the cruise control would stop working and the cruise light starts blinking. Often times I can just turn the bike off then on via the key and it'll work just fine again. However, since it was becoming more and more annoying since I always use the CC when I ride, I decided to try and fix the issue myself and so far so good. I didn't mention it in the video, but i hooked my OBD 2 reader to the bike and saw a fault code for the front/rear brake switch. That's what prompted me to take this course of action in the first place. The cruise switch and the brake light switch are exactly the same and are designed to activate at the same time. What causes the issue is when the brake light switch gets stuck "on", even for a split second, while the cruise switch is off. This causes the ECU to think there's a short. I see no issue with splicing the wiring the way I did as the light goes on and the cruise de-activates when pulling the front brake. I also went ahead and cleaned the contacts on the rear brake switch as well for good measure.
Post by RedAndBlack on Dec 5, 2021 23:39:40 GMT -7
I believe there's a recall or a tech bulletin on faulty brake light/cruise control sensors as well. Could be your unit is affected.
Post by willl84 on Dec 8, 2021 7:13:46 GMT -7
I believe there's a recall or a tech bulletin on faulty brake light/cruise control sensors as well. Could be your unit is affected. There is, I had mine fixed this past spring. Definitely call the dealer with your VIN and see if the recall applies to your bike
beefytom
Post by beefytom on Dec 9, 2021 20:51:59 GMT -7
I believe there's a recall or a tech bulletin on faulty brake light/cruise control sensors as well. Could be your unit is affected. There is, I had mine fixed this past spring. Definitely call the dealer with your VIN and see if the recall applies to your bike Unfortunately, it does not. However, I haven't had an issue since.
Post by willl84 on Dec 10, 2021 12:43:06 GMT -7
There is, I had mine fixed this past spring. Definitely call the dealer with your VIN and see if the recall applies to your bike Unfortunately, it does not. However, I haven't had an issue since. Well that sucks but it's good at the same time lol
