darinmac
Post by darinmac on Oct 29, 2021 21:19:51 GMT -7
This is my first of what will probably be many questions about my 2013 FZ1. Hello everyone, I'm excited to be a part of your forum. Okay so I basically bought for dirt cheap 2013 it had a bent frame and fork tube. As a result I've had to basically remove everything from one bike and put it on doing nothing. All has gone well until I got to the wiring harness portion of this project. One of my questions is on the coil wiring harness there's a two pin connector with a red wire white stripe and brown wire red stripe. Service manual wiring diagram pictures aren't helping much. If anybody can help me out there I'd greatly appreciate it because this has been doing my head in. I had everything hooked up for the most part as far as I knew and all I would get was a clicking noise coming from my starter solenoid and that's what prompted me to uninstall said harness and start over trying to figure out what I may have missed any help is greatly appreciated.
Post by RedAndBlack on Oct 30, 2021 0:29:35 GMT -7
Hello, welcome to the forum. Unfortunately electrical harnesses are beyond my expertise.
Just wanted to let you know that this forum is for the 2015+ FZ/MT-10s that replaced the FZ1s. I'm not sure actually how much the bikes are different from the FZ1s in the electrical category, but I know they are considered to be different generation bikes and with the amount of electronics that were added to the FZ/MT 10s, I imagine our wiring harnesses are a bit more complicated.
I hope there's someone here that can still help you, but you might have better luck on some of the dedicated FZ1 forums. Good luck!
