denieljone
Post by denieljone on Oct 21, 2021 20:54:31 GMT -7
i have a 2019 mt 10 and it comes with the stock quick shifter, working like a charm just wanna know can i use it without releasing the gas when shifting?
Post by Deleted on Oct 22, 2021 6:28:54 GMT -7
Yep that is what the quickshifter is for otherwise you are just using the old throttle chop method anyone can use without a quickshifter.
Post by willl84 on Oct 22, 2021 9:53:35 GMT -7
i have a 2019 mt 10 and it comes with the stock quick shifter, working like a charm just wanna know can i use it without releasing the gas when shifting? That's exactly what it's for. Hold the throttle and bang the shifter
3lseeker
Post by 3lseeker on Oct 22, 2021 11:44:02 GMT -7
Yeah.....that's the FUN part!
Post by RedAndBlack on Oct 22, 2021 13:48:22 GMT -7
It is recommended to still use the clutch from 1st to 2nd, since this shift has to pass through the nuetral gear and is usually the source of transmission failures.
denieljone
Post by denieljone on Nov 10, 2021 20:07:22 GMT -7
do i need to set some thing to make that happen? because i keep on trying to shift without releasing the throttle but it wont,
Post by willl84 on Nov 11, 2021 10:29:35 GMT -7
do i need to set some thing to make that happen? because i keep on trying to shift without releasing the throttle but it wont, If your dash doesn't have the little "QS" icon showing up then it's not enabled
denieljone
Post by denieljone on Nov 18, 2021 20:29:01 GMT -7
it does show a QS, but its really hard to shift without releasing the throttle thats why im not forcing it. scared it'll break down
Post by willl84 on Nov 19, 2021 9:04:05 GMT -7
it does show a QS, but its really hard to shift without releasing the throttle thats why im not forcing it. scared it'll break down Mine was flaky for a while earlier this year - it'd shift a few times just fine then would refuse to work. It's been flawless for the last couple months though, no idea what the issue was. I'm looking at replacing it with the Translogic setup with an autoblipper anyways though
jm1
Post by jm1 on Nov 20, 2021 3:55:06 GMT -7
it does show a QS, but its really hard to shift without releasing the throttle thats why im not forcing it. scared it'll break down It works better higher in the rev range, although should still work down to around 4k rpm.
denieljone
Post by denieljone on Nov 22, 2021 20:57:37 GMT -7
do you guys know what should i do? would love to use the QS
Post by hooli on Nov 22, 2021 21:42:48 GMT -7
Chain tension is also critical to QS operation.
Post by willl84 on Nov 23, 2021 6:15:42 GMT -7
do you guys know what should i do? would love to use the QS You didnt happen to switch to GP shift style did you?
