Post by parthz8 on Sept 22, 2021 15:01:29 GMT -7
I always buy tires for my Sportbikes and MT-10 from U.S.A. This time Bridgestone Battlax S22 - 200/55 ZR 17 (78W) Tires are OUT OF STOCK everywhere!!
Any idea who can have these tires available? I have freight forwarder in Houston-Texas to ship them international for me, just matter of getting them...
Post by hooli on Sept 22, 2021 17:00:49 GMT -7
Can't you ride on something else until they're back in stock?
Post by mt10orc on Sept 23, 2021 18:25:17 GMT -7
That sucks. I know the have the 190’s in stock.
Post by willl84 on Sept 24, 2021 6:14:28 GMT -7
Why are you putting a 200 on this bike?
Post by sdshawn on Sept 24, 2021 6:37:18 GMT -7
190 55 17 is oem like above mentioned. I personally not sold on the battle ax that I've ran on my last 2 yamahas they came with. Tires for me are becoming a trial ride thing .
I replaced the battle ax on my 10 with michelin 2ct and have been very happy with grip I think even better the the Bridgestone and so far are lasting longer for around the same price. Getting ready to switch again to the pirelli angel gt to give them a try for even better milage with grip to be determined.
I'm glad I made the change to experience the different brands not limit situations your finding your self in. I'm not a knee dagger on the local roads but do get into the chicken strip on occasion. Best thing is do the research and try different brands and who knows you might be happier with something other then oem.
Post by RedAndBlack on Sept 24, 2021 10:24:12 GMT -7
Sometimes you just have to call around places locally to see who has it in stock.
Post by parthz8 on Sept 24, 2021 13:57:50 GMT -7
Why are you putting a 200 on this bike? Sorry, forgot to mention 200 for my R1M.
Post by parthz8 on Sept 24, 2021 13:59:04 GMT -7
190 55 17 is oem like above mentioned. I personally not sold on the battle ax that I've ran on my last 2 yamahas they came with. Tires for me are becoming a trial ride thing . I replaced the battle ax on my 10 with michelin 2ct and have been very happy with grip I think even better the the Bridgestone and so far are lasting longer for around the same price. Getting ready to switch again to the pirelli angel gt to give them a try for even better milage with grip to be determined. I'm glad I made the change to experience the different brands not limit situations your finding your self in. I'm not a knee dagger on the local roads but do get into the chicken strip on occasion. Best thing is do the research and try different brands and who knows you might be happier with something other then oem. Thanks for the info! i will definitely look into Michelin 2ct! (Not a huge fan of Pirelli)
Post by willl84 on Sept 26, 2021 3:42:19 GMT -7
Why are you putting a 200 on this bike? Sorry, forgot to mention 200 for my R1M. That makes sense then lol
Post by parthz8 on Sept 26, 2021 14:28:54 GMT -7
Quick update: got S22 200-55R17 from UK. They are back in stock in US too..
Post by sdshawn on Sept 29, 2021 16:29:17 GMT -7
Just a correction on the 2ct it does not last longer then the battleax, I'm at 2600 mi just about to the wear bar down the middle vs 3700 on the Bridgestone so no wonder the grip was really good. The pirelli is on its way I'm curious on how that tires holds up compared to the others.
Post by RedAndBlack on Sept 29, 2021 22:09:13 GMT -7
You sure you're not running on lower pressures? The stock Bridgestones come 36/42 cold pressures. A lot of people get their second set of tires and mechanics set the pressures in the low 30s usually. The tires definitely grip better at these pressures but accelerate tire wear, especially on a 1000. They should be getting pretty similar mileage and arguably, the Power 2CT should get a bit more in the middle given it's dual compound.
There's also 2 different Michelin 2CTs that people often get confused. There's Road and Power and a huge difference in mileage.
Post by sdshawn on Sept 30, 2021 6:59:08 GMT -7
I run pressure at 36/42 and I check before every ride do to possible scalping these tires are prone to if not running at correct pressure.
These are power pilot 2ct that were recommended by sales at motorsport he said I should expect at least 6k out of them. Well so I know how that turned out and moving on to another type tire and see how that goes. I'm actually going to run the pirelli rear with the 2ct in front wich alot of people say not to do .
I have at least 50% left on the front so I'm going to run it out. And if they seem unstable or scary together then I'll get the matching front Otherwise I'll just run the front out and replace when it's time..
Post by RedAndBlack on Sept 30, 2021 9:18:28 GMT -7
That's pretty crazy that you're not getting that much mileage out of them. That's what I would expect, 5-6k
Which Pirelli are you going to run?
Post by willl84 on Sept 30, 2021 10:24:18 GMT -7
36/42? I always run my bikes at 32/36 for the street
Post by sdshawn on Sept 30, 2021 10:50:17 GMT -7
I ordered the pirelli angel gt sport touring and not the newer gt2 I could get it before this weekends ride but I'm going to squeeze out the last few hundred miles out of the 2ct Palomar to Julian.
36 in the rear might have helped with the wear down the middle makes sense I'm kinda use to the pressure I'm running and I never had the 2ct break traction unless on decel hard braking coming into a turn.
Post by RedAndBlack on Sept 30, 2021 20:17:57 GMT -7
36/42? I always run my bikes at 32/36 for the street That's just what they come stock. I run 31/30 in the summer. 😆😎
Post by parthz8 on Oct 1, 2021 1:17:57 GMT -7
36/42? I always run my bikes at 32/36 for the street That's just what they come stock. I run 31/30 in the summer. 😆😎 I always keep 36frnt/42rear as per OEM sticker on swingarm.... I got ~7500Kms on battlax RS10 (Stock) came on R1M. Now its time change both on number of years and wear. I am also running 36frnt/42rear on my OEM Battlax MT-10 S21s... not even Kms to determine wear on these..
slipwrist
Post by slipwrist on Jan 29, 2023 18:19:30 GMT -7
No reason to run a 200, just sacrifice handling. I generally trust the manufacturer on what to put in the bike, they designed and built it, I think they probably know best.
Post by parthz8 on Feb 1, 2023 11:56:27 GMT -7
No reason to run a 200, just sacrifice handling. I generally trust the manufacturer on what to put in the bike, they designed and built it, I think they probably know best. Agree. But 200 i bought was for my R1M rear (OEM size).
