steverino
Post by steverino on Aug 20, 2021 0:46:35 GMT -7
Hi my name is Steve I’m rebuilding a crashed 18 MT-10. Looks like it went down in grass or mud because there is no road rash just tore up fairings and the headlight area took a hit. I didn’t get a few pieces, they apparently got “lost” along the way. I’m trying to find the right side tank scoop and the blue right side tank cover. I’m trying to figure out where connector 7 connects to. Somewhere behind the headlights once I get that back together. Now I’ll see if I can add some pictures to show what I’m talking about. If there aren’t any. It didn’t work. This is my first Yamaha. I’ve got a couple Harleys, an Indian and a couple Honda’s. Thanks for your help! Steve
mclovin
Post by mclovin on Aug 20, 2021 6:03:31 GMT -7
I've had to replace some of the body panels on my bike and Partzilla was the best source and best prices. Since there are multiple colors, not everything is going to be in stock. They pull out of warehouse and get it done as quickly as factory ships.
vulcanator
Post by vulcanator on Aug 21, 2021 12:56:01 GMT -7
Good luck with the rebuild. Just discovered today that mrcycles.com does OEM parts cheaper than Partzilla. Look forward to seeing pictures of your rebuilt bike.
redlinez
Post by redlinez on Aug 22, 2021 5:04:00 GMT -7
I just checked the comfort seat and it's $273.50 at MRCycle and $258.30 at Partzilla. MRCycle was about 40 cents cheaper on an oil filter, so I guess you would want to bounce them off each other.
