Post by parthz8 on Aug 15, 2021 15:13:30 GMT -7
My TwoBros exhaust link pipe is stuck on header pipe connections. (muffler/silencer came out). Tried WD-40 for 3 days but no luck. Any ideas/help how to get it loose and remove?
weehe
Post by weehe on Aug 15, 2021 15:27:45 GMT -7
Try PB blaster.
Post by RedAndBlack on Aug 18, 2021 18:52:19 GMT -7
Any luck? I would try heat. Take a torch to the pipe but a bit back from where they join so you don't heat both pipes. Wrap something around the bike maybe back near the hanger weld like wire, tubing, or rope to help give you some leverage and pull in a twisting motion.
Post by parthz8 on Aug 20, 2021 4:06:03 GMT -7
Sorry, PB Blaster not available here
Post by parthz8 on Aug 20, 2021 4:07:37 GMT -7
Any luck? I would try heat. Take a torch to the pipe but a bit back from where they join so you don't heat both pipes. Wrap something around the bike maybe back near the hanger weld like wire, tubing, or rope to help give you some leverage and pull in a twisting motion. Not yet. Thanks for the suggestion. i will try heat and above method. BTW i am worried to use torch (dont want to damage oil sump/engine which is very near to joint).
greenhornet
Post by greenhornet on Aug 26, 2021 14:47:23 GMT -7
Smash with a rubber Hammer on the co2 nuts on both sides,to the rear wheel.
Post by parthz8 on Aug 27, 2021 12:59:22 GMT -7
Smash with a rubber Hammer on the co2 nuts on both sides,to the rear wheel. Tried but not enough room/play to get that force from rubber hammer...
Post by sdshawn on Aug 27, 2021 17:54:05 GMT -7
This might sound silly but it's worked for me before removing turbo on a diesel with carbon sult build up over a long time. If you can get can of goof off pro strength remover it comes in a yellow can . This stuff eats carbon build up like you would not believe.
Anyway spray it in the seem where they meet alot like soak it . You should still have the mesh gasket I would assume so give it time to eat the carbon around it.
Now the silly part if you have something that vibrates you can vibrate area to help break up the carbon grip it has on the two pieces . And if that does not work then it's dremnel time and cut a slit carefully if you want to salvage the mid pipe.
Post by parthz8 on Sept 26, 2021 14:35:11 GMT -7
Got them out! Used industrial heat gun to blow link pipe and used freezed medical bag on headers. Hammered both sides simultaneously and Voila!
mclovin
Post by mclovin on Sept 28, 2021 8:33:55 GMT -7
This might sound silly but it's worked for me before removing turbo on a diesel with carbon sult build up over a long time. If you can get can of goof off pro strength remover it comes in a yellow can . This stuff eats carbon build up like you would not believe. Anyway spray it in the seem where they meet alot like soak it . You should still have the mesh gasket I would assume so give it time to eat the carbon around it. Now the silly part if you have something that vibrates you can vibrate area to help break up the carbon grip it has on the two pieces . And if that does not work then it's dremnel time and cut a slit carefully if you want to salvage the mid pipe.
The Goo Off for carbon build up is a great tip. Never would have thought of it.
