gary4279
Post by gary4279 on Aug 6, 2021 4:10:28 GMT -7
Mt10 piston and piston connecting rod can change R1 forging piston parts? Is the R1 engine the same as the MT10 engine?
Post by willl84 on Aug 6, 2021 4:28:58 GMT -7
From what I've read the connecting rods and camshafts are different as well as the cylinder head porting. I don't remember seeing anything about the pistons being different but they very well may be.
The MT-10 has 12:1 compression where the R1 has 13:1 so I'm sure the pistons are different as the bore and stroke are the same between the two at 79x50.9mm.
gary4279
Post by gary4279 on Aug 6, 2021 4:40:55 GMT -7
From what I've read the connecting rods and camshafts are different as well as the cylinder head porting. I don't remember seeing anything about the pistons being different but they very well may be. The MT-10 has 12:1 compression where the R1 has 13:1 so I'm sure the pistons are different as the bore and stroke are the same between the two at 79x50.9mm. Thank you so much
mclovin
Post by mclovin on Aug 6, 2021 9:38:00 GMT -7
Were you asking out of curiosity or because you were thinking of changing them out?
