xroadracer
Post by xroadracer on Jul 16, 2021 4:53:40 GMT -7
Has anyone installed these? I mounted them yesterday for a little more forward riding position. The shift side was straightforward, however, the brake side not so much. Call me retarded, but I struggled with the brake light switch and lever return spring. I tossed the brake light switch as I normally only use it in combination with the front brake. The deal is, the return spring mounts at an angle, has a very short throw and doesn't have much tension. If I do use the rear brake, the spring isn't pulling the lever back to its original position. When I put the bike on the stand, spin the rear wheel and press the brake pedal, it drags on the disc. I'll call them today and try to find out what I'm doing wrong. I could 't find any vids of this installation. Thanks!
Post by hooli on Jul 18, 2021 15:34:19 GMT -7
Both Woodcraft and Graves market rear brake return springs.
