nitrohvy
Post by nitrohvy on May 15, 2021 12:45:40 GMT -7
I need some help fellas: Suddenly at the 700mi mark, my 2020 has developed a ton of play in the shifter. Let me explain: On a hard suddenly downshifts were being missed and over a few miles it just went to shit. Shift pedal seemingly not returning to position. Staying too far down or up. Now got it in the garage and the play between 1st and 2nd is way too much. I installed Woodcraft rearsets about 250mi ago but those two or three short rides were money. No issues. Yes, I replaced the factory shifter pedal. But no adjustment was necessary and there was no difference in shift performance initially. Now, possibly the new Woodcraft pedal is way more stiff than factory pedal and is putting more stress on shift-linkage? What I can't understand is the play inbetween the gears makes no sense from an outside of the bike view. Maybe I can attach a vid of the play. The shift shaft (top of linkage connects to) seems like it moves way too much between gears suddenly. What should I adjust or do to inspect for issues? The linkage is tight but the QS sensor (top of linkage)spins feely but the opposing thread nuts are tight. I have never taken a wrench to them. They are tight. The chain is slacked out and it's time for some tension. Need to do that. But look at this play:(attaching a video separately)
nitrohvy
Post by nitrohvy on May 15, 2021 13:12:22 GMT -7
nitrohvy
Post by nitrohvy on May 15, 2021 13:17:40 GMT -7
Can't seem to get the vid to upload. Cheesy imgur not working well with my android. I don't have a pc. This should be doable all via mobil. This is 2021! I need some pro help here. Something is way wrong.
nitrohvy
Post by nitrohvy on May 15, 2021 13:24:40 GMT -7
Post by parthz8 on May 15, 2021 14:01:07 GMT -7
nitrohvy
Post by nitrohvy on May 15, 2021 19:32:12 GMT -7
nitrohvy
Post by nitrohvy on May 15, 2021 19:36:02 GMT -7
parthz8. Thank you. I feel better about that. Now, I don't know what to think. I will tension the chain back to spec, it's out for sure. This can certainly cause shitty shifting. It just seems the shifter is too soft feeling, not returning properly when actually riding and downshifting, it's quite possible, it's all my chain tension. I will report back tomorrow. Thanks for the comparison. I appreciate your consideration. Nitro
nitrohvy
Post by nitrohvy on May 15, 2021 19:37:28 GMT -7
I think I will also remove the linkage connector bolt swivel and grease it a bunch. Retorque my shift lever as well, just because I'm there and I don't know the problem.....
Post by parthz8 on May 16, 2021 10:27:06 GMT -7
Sure nitrovy- Let me know if you need any information from Service Manual on this (in case you dont have it handy...)
