chmt
Post by chmt on May 12, 2021 17:15:32 GMT -7
Has anyone running these been able to get the bars to turn all the way? I went with the 1" and whether I place them in the up or down position they hit the screen and gauge cluster. I removed the screen and it gets a bit more clearance but still not enough to make a U turn on regular road.
I called Stoltec, where I purchased the kit, and they said that's why they don't recommend them. Wish they would've told me that before purchasing them!
They feel great, look even better, but I can't even lock the steering because I can't turn the bars that far. I'm not sure what else to tweak since I've tried the control at several angles already.
kohtachi
Post by kohtachi on May 20, 2021 12:53:10 GMT -7
I had to move the front bake line. Its tight but, you can definitely lock handle left and right without hitting the tank. Also, the windshield will get in the way so you need to modify it or change it for an aftermarket part.
good luck
monkeymt10
Post by monkeymt10 on May 23, 2021 21:47:08 GMT -7
Installed the same setup last month. Bars clear in the up and down position when the brake lines are rotated I did have to mod the windshield by removing a inch for each side. I will not return to the stock bars after these. Also or can order 2 or 3 inch risers to gain clearance if desired.
Post by hooli on May 24, 2021 7:16:50 GMT -7
I replaced my stock screen with an aftermarket Puig copy. I have full clearance lock-to-lock with my Woodcraft setup. It takes some fine tuning of the bars but it can definitely be done.
chmt
Post by chmt on May 27, 2021 9:58:56 GMT -7
Do you guys have radial MCs? There is now ay it will clear with the stock one, even sliding the bars all the way out which makes them wider than the stock bars. I removed the screen and they hit the gauge cluster on both sides.
Post by hooli on May 27, 2021 11:06:22 GMT -7
Do you guys have radial MCs? Yes, running the stock radial MC from a 2015 R1.
chmt
Post by chmt on May 27, 2021 12:09:37 GMT -7
Clutch side clears to full lock?
Post by hooli on May 27, 2021 13:56:37 GMT -7
Clutch side clears to full lock? Mine clears lock-to-lock.
chmt
Post by chmt on May 28, 2021 4:24:26 GMT -7
Thanks for the pictures hooli. Are those the standard length bars? I don't think my bars are that long.
Post by hooli on May 28, 2021 8:42:42 GMT -7
Yes, those are the bars that came with the kit. They're slightly longer than the standard bars that Woodcraft sells, but you can always loosen the pinch bolt on the riser and tailor the overall length.
natesnick
Post by natesnick on Aug 15, 2021 8:50:51 GMT -7
Yes, those are the bars that came with the kit. They're slightly longer than the standard bars that Woodcraft sells, but you can always loosen the pinch bolt on the riser and tailor the overall length. Hey those look awesome! Can you post a picture of you or someone sitting with them? And a full side picture of them? Love the set up!
phanomenal10
Post by phanomenal10 on Aug 19, 2021 12:52:31 GMT -7
Do you guys have radial MCs? Yes, running the stock radial MC from a 2015 R1. Is the r1 master cylinder plug and play with the brake light switch?
Post by hooli on Aug 23, 2021 18:26:04 GMT -7
Yes, running the stock radial MC from a 2015 R1. Is the r1 master cylinder plug and play with the brake light switch? Yes. Or at least mine was.
