cadezigns1
Post by cadezigns1 on May 10, 2021 17:53:32 GMT -7
In the rebuilding stage of a 2019 MT-10. I need to replace the brake lines. I can use OEM....but I would like to see what you guys may have upgraded too? I am looking at Spiegler Stainless Braided brake lines but I can't find any good or negative info on them.
Any suggestions?
Post by hooli on May 10, 2021 21:36:24 GMT -7
Core Moto. But then I've bypassed my ABS pump.
dxdt
Post by dxdt on May 10, 2021 22:04:49 GMT -7
Core Moto. But then I've bypassed my ABS pump. Did you give them custom measurements to use? I don't see an MT 10 option
Post by parthz8 on May 11, 2021 17:06:47 GMT -7
Hi cadezigns1 I am planning to replace my brake line currently OEM rubber kind to Stainless Braided brake lines on MT10 (after factory warranty ends in couple of months). My R1M stock front is stainless braided brake line far superior and powerful braking... This video might be helpful (Stoltec Moto Spiegler MT-10 Stainless Steel Brake Line Install): Tip: its also worth to change brake pads front and rare to Brembo on MT10. Replacement/Installation is very easy. Immediate difference in biting power is observed with Brembos... Front Brembo Racing: BB-15HH; Part: 07YA23SR Qty: 2 Rare Brembo: BB-9GG; Part: 07HO36SP www.carpimoto.it/en-US/Bike_Yamaha_MT-10/Brand_Brembo/47926_07YA23SR-Brake-Pads-Brembo-07YA23SR-Sintered-Racing-1-couple-for-1-disk-for-Yamaha.htm
Post by RedAndBlack on May 12, 2021 9:33:07 GMT -7
I did the R1 master cylinder upgrade. You should consider it if you're going to do the lines. You can get one relatively cheap (I got mine under $100 with the reservoir)
Some said stock length will work but I got a few extra inches since the banjo bolt connects a little further away than the stock master. You'll also have to figure out how to mount the reservoir. Obviously brembo has a kit but I went with a ladybird mount. I also had to file down the brake switch slightly as it was coming on a bit delayed.
I have spiegler on the FZ10 but I think I felt the coremoto on my last track bike were a little better. At least as far as I perceived the quality. Performance seems exactly the same though and I imagine there's not much to be gained or lost between the different brands.
As far as brake pads, I absolutely swear by SBS brake pads.
Post by willl84 on May 12, 2021 10:04:20 GMT -7
weehe
Post by weehe on May 13, 2021 16:53:21 GMT -7
I was planning on getting that one as well. But do you have to get a new lever? Just seems odd they specifically say you have to get your own.
Post by willl84 on May 14, 2021 6:34:17 GMT -7
I was planning on getting that one as well. But do you have to get a new lever? Just seems odd they specifically say you have to get your own. You'll have to either order the OEM R1 lever or get a set here: stoltecmoto.com/shop/yamaha/fz-10/17-fz-10-asv-f3-adjustable-unbreakable-levers/Under "Lever Selection" they have listings for a set of both levers, shorty or standard, for either stock or R1 master cylinder.
weehe
Post by weehe on May 15, 2021 16:03:18 GMT -7
I was planning on getting that one as well. But do you have to get a new lever? Just seems odd they specifically say you have to get your own. You'll have to either order the OEM R1 lever or get a set here: stoltecmoto.com/shop/yamaha/fz-10/17-fz-10-asv-f3-adjustable-unbreakable-levers/Under "Lever Selection" they have listings for a set of both levers, shorty or standard, for either stock or R1 master cylinder. Dang, just got ASR levers and don't really want to replace it already.
Post by hooli on May 16, 2021 23:39:31 GMT -7
Core Moto. But then I've bypassed my ABS pump. Did you give them custom measurements to use? I don't see an MT 10 option Yes, I did. Dual lines direct from front MC to calipers, left side measured 35", right side 32" The rear line was 24". Bear in mind that these didn't include the end fitting lengths.
