oldguymadspeed
Post by oldguymadspeed on Apr 24, 2021 6:12:15 GMT -7
When I bought my used MT10 a few days ago I took off the seat and noticed a quick connect harness not connected to anything. Did some research and this part is missing. What is it? The circled part is NOT on my bike. Just an empty space.
yzfbob
Post by yzfbob on Apr 24, 2021 10:21:03 GMT -7
That appears to be the servo motor for the exup valve. Your bike has most likely modded with a ecu reflash amongst other things as exhaust etc.
oldguymadspeed
Post by oldguymadspeed on Apr 24, 2021 13:27:00 GMT -7
That appears to be the servo motor for the exup valve. Your bike has most likely modded with a ecu reflash amongst other things as exhaust etc. Thanks for the response and you are correct. I just found out the original owner (older guy like me but owns with 12 plus bikes) said he removed the cables and Servo motor and wired the exhaust valve to the full open position. He Told the dealer he does this on all his new bikes right away. Fortunately he kept all the original parts and is dropping them at the dealer for me to PU next week.
