akiaki
Post by akiaki on Apr 21, 2021 16:52:28 GMT -7
Anyone know if R1 crankcase cover BX4-15411-00-00 fit FZ10 (replacing B67-15411-00-00 )?
Just happen to have a set of R1 GBRacing covers on hand, would be cheaper if I can just replace the crankcase cover with a used R1 cover. I would end up spending less money, and a clean FZ10 crankcase cover on the side just in case something happens.
Post by willl84 on Apr 22, 2021 5:05:36 GMT -7
If the covers you have are for a 2015-2019 R1 then I would think they'd fit. Seems most other things from that gen R1 are interchangable
wingnut03
Post by wingnut03 on Apr 22, 2021 18:14:31 GMT -7
the cover on the left,generator will not fit .the r1 has a smaller gen.winding.seems they put a bigger generator in the 10 for touring accessories.
Post by willl84 on Apr 23, 2021 4:20:58 GMT -7
the cover on the left,generator will not fit .the r1 has a smaller gen.winding.seems they put a bigger generator in the 10 for touring accessories. That makes sense
