jboy
Post by jboy on Mar 28, 2021 17:07:52 GMT -7
Post by sdshawn on Mar 28, 2021 21:10:37 GMT -7
How is the 520 set up I'm looking into that when it comes time. I hope it vwill hold up like the stock set up just curious on you thoughts on what you think.
jboy
Post by jboy on Mar 29, 2021 11:33:26 GMT -7
A quality 520 DID is plenty strong, and a gold one looks better too. I got a steel rear for long life.
manic
Post by manic on Mar 29, 2021 21:10:30 GMT -7
Would you take $60?
jboy
Post by jboy on Mar 30, 2021 16:08:37 GMT -7
I PM'd you
manic
Post by manic on Mar 31, 2021 10:19:21 GMT -7
PM replied to.
manic
Post by manic on Apr 8, 2021 17:04:23 GMT -7
Got em, Thanks!
Post by sdshawn on Apr 9, 2021 8:15:20 GMT -7
Did you notice any difference power noise anything would be the reason for the change in size? Would find the best I can get and in gold.
yzfbob
Post by yzfbob on Apr 9, 2021 14:37:55 GMT -7
I’ve always been told it’s the lighter weight and the effect on rotating mass.
Post by sdshawn on Apr 9, 2021 16:32:18 GMT -7
I've read that also but jboy has done it so want to know if you can feel the difference or just a mind game . It makes sense weight wise but ide rather have strength instead of a couple of hps on this bike power is abundant for me anyway
yzfbob
Post by yzfbob on Apr 10, 2021 1:46:32 GMT -7
The strength was my concern before I did the conversion on my 97 YZF1000 from 530 to 520. Never had an issue for over 14 years of use.
Post by sdshawn on Apr 10, 2021 7:08:51 GMT -7
I guess I'm not asking the question right, Did you notice a difference in power? whats the point unless the difference in rotating mass is not enough to feel from the seat of your pants otherwise why do it.
yzfbob
Post by yzfbob on Apr 10, 2021 12:33:33 GMT -7
Can’t say for sure as we added CV carbs and a custom air box at the same time. The engine builder did say it was easier on the counter shaft bearings and rear wheel Cush drive, wish I could be better help.
Post by sdshawn on Apr 10, 2021 17:03:42 GMT -7
When it comes time for the new set I guess I will know wich direction to go with maybe even a gear change . Even then I would want to go longer in the gears right now to much bottom End I think but I don't want to drag first gear anymore then I do leaving lights but I'm thinking 1 or 2 teeth down in the rear might calm it down on the bottom. The g2 tamer helped alot with that but it's still just a freaking animal on bottom and mid.
jboy
Post by jboy on Apr 11, 2021 7:26:02 GMT -7
Look at the tensile strength chart on DID chains. A 520 is plenty strong. It's not super noticeable, but why run a heavier chain if you don't need to ?
Post by willl84 on Apr 12, 2021 8:45:59 GMT -7
Look at the tensile strength chart on DID chains. A 520 is plenty strong. It's not super noticeable, but why run a heavier chain if you don't need to ? Because the bigger chains last longer so you don't need to replace them as often. You'll never even notice a difference between a 520 and 525 on the street
Post by sdshawn on Apr 12, 2021 9:34:16 GMT -7
I guess if I where racing it might make a difference but if I can get more miles out of the 525 then a 520 I'll just stick with the oem size but thanks for helping make up my mind.
