vullnet
Post by vullnet on Feb 27, 2021 14:37:20 GMT -7
Got my bike back from the shop after an accident in December, swapped out the exhaust last week and noticed a leak by the radiator hose I tightened it with channel locks but it's still slowly dripping, How do I go about fixing this?
Post by willl84 on Feb 27, 2021 16:29:36 GMT -7
Tightened what with channel locks? The coolant leak is probably coming from that hose clamp which needs an appropriate size socket or screwdriver to tighten
vullnet
Post by vullnet on Feb 27, 2021 16:30:43 GMT -7
Tightened what with channel locks? The coolant leak is probably coming from that hose clamp which needs an appropriate size socket or screwdriver to tighten yup channies. I don't see a hose clamp, on the inside?
Post by willl84 on Feb 27, 2021 16:33:25 GMT -7
vullnet
Post by vullnet on Feb 27, 2021 16:44:32 GMT -7
Didn't realize you meant that one lol. Think you're right, felt some fluid on it. Was a phillips head so I tightened it, hopefully it's fine, i'll check back later. yup channies. I don't see a hose clamp, on the inside?
