weehe
Post by weehe on Feb 22, 2021 22:21:45 GMT -7
Currently have a stock header, leo vince link pipe and akra slip on. Looking at the R1M titanium header. Anyone that has made the swap, does it change the exhaust note at all? Currently my setup is extremely deep, wouldn't mind it being a bit higher/tinny. Thinking the titanium header might just do that, and look a lot better.
Post by clayton on Feb 23, 2021 5:50:59 GMT -7
Currently have a stock header, leo vince link pipe and akra slip on. Looking at the R1M titanium header. Anyone that has made the swap, does it change the exhaust note at all? Currently my setup is extremely deep, wouldn't mind it being a bit higher/tinny. Thinking the titanium header might just do that, and look a lot better. Sound will probably be the same! Just changes Appearance
Post by willl84 on Feb 23, 2021 7:12:26 GMT -7
Currently have a stock header, leo vince link pipe and akra slip on. Looking at the R1M titanium header. Anyone that has made the swap, does it change the exhaust note at all? Currently my setup is extremely deep, wouldn't mind it being a bit higher/tinny. Thinking the titanium header might just do that, and look a lot better. Sound will probably be the same! Just changes Appearance Exactly this. It'll sound the same but just look nicer
weehe
Post by weehe on Feb 23, 2021 9:23:05 GMT -7
Thanks, will see if I can lean up the stock headers first then.
Post by mindcrime79 on Feb 23, 2021 12:37:01 GMT -7
A tuner told me that it would have to be retuned if you changed to titanium....not sure how that would make sense...
Post by willl84 on Feb 23, 2021 19:06:35 GMT -7
A tuner told me that it would have to be retuned if you changed to titanium....not sure how that would make sense... Yea that makes zero sense
Post by hooli on Mar 1, 2021 8:06:38 GMT -7
I'd find another "tuner."
Post by mindcrime79 on Mar 1, 2021 10:12:02 GMT -7
Mmmm
sfbayrider
Post by sfbayrider on Mar 6, 2021 16:26:47 GMT -7
I have the R1M header, because the rest of my exhaust is titanium and I wanted it all to be the same.
Sound didn't change.
olivierzx
Post by olivierzx on Mar 7, 2021 10:49:17 GMT -7
Post by mindcrime79 on Mar 7, 2021 11:33:31 GMT -7
$450 chinese metal...🤔
weehe
Post by weehe on Mar 7, 2021 19:30:43 GMT -7
Yeah... That's more than getting a real one on ebay.
redlinez
Post by redlinez on Apr 23, 2021 12:38:51 GMT -7
These things appear to be getting expensive and one said new when it looked used to me. Any links to one that's legit? I assume there's a substantial gain other than matching titanium looks.
Post by willl84 on Apr 24, 2021 2:55:16 GMT -7
These things appear to be getting expensive and one said new when it looked used to me. Any links to one that's legit? I assume there's a substantial gain other than matching titanium looks. There's zero gain except for the looks
Post by heathhudnall on Aug 18, 2021 17:03:34 GMT -7
These things appear to be getting expensive and one said new when it looked used to me. Any links to one that's legit? I assume there's a substantial gain other than matching titanium looks. There's zero gain except for the looks Agreed and they don't look good like the aftermarket Ti headers. They don't have the beautiful heat colors. Mine is just gray.
Post by dkim213 on Aug 18, 2021 20:03:36 GMT -7
There's zero gain except for the looks Agreed and they don't look good like the aftermarket Ti headers. They don't have the beautiful heat colors. Mine is just gray. These are the stock R1 headers after a bit of gray scotch brite and polish.
Post by willl84 on Aug 19, 2021 4:31:42 GMT -7
Agreed and they don't look good like the aftermarket Ti headers. They don't have the beautiful heat colors. Mine is just gray. These are the stock R1 headers after a bit of gray scotch brite and polish. Was going to say that. You need to really clean them good with scotch brite and stuff and then they'll look real nice. From what I hear they eventually turn back to a dull grey though
Post by heathhudnall on Aug 19, 2021 16:53:35 GMT -7
Agreed and they don't look good like the aftermarket Ti headers. They don't have the beautiful heat colors. Mine is just gray. These are the stock R1 headers after a bit of gray scotch brite and polish. That looks good. How much work did you have to put in?
Post by heathhudnall on Aug 19, 2021 16:55:33 GMT -7
These are the stock R1 headers after a bit of gray scotch brite and polish. Was going to say that. You need to really clean them good with scotch brite and stuff and then they'll look real nice. From what I hear they eventually turn back to a dull grey though I tried once, but I was afraid to go too deep and just have scratched up headers.
Post by dkim213 on Aug 22, 2021 8:44:19 GMT -7
These are the stock R1 headers after a bit of gray scotch brite and polish. That looks good. How much work did you have to put in? I don’t remember exactly. I just gave mine to my R1 buddy and I’ll be polishing up his to put in my bike. I’ll try to share how long that takes
