kaeqt
Post by kaeqt on Jan 24, 2021 20:02:21 GMT -7
Hi all,
I have been noticing that my clutch has not been disengaging fully. A few examples,
1. When coasting with the clutch in around 20kmph, if I blip the throttle I can hear and feel a clunk somewhere near the front sprocket/chain area. 2. I can hear and feel engine braking when clutched in, in first gear. When I give it a bit of throttle (still clutched in), the bike was able to coast freely. 3. I have to give it a bit of gas to get it to neutral from gear 1 when bike is hot.
The bike runs fine, shift through the gears fine and smooth when riding. Am running a 10W50 oil. Clutch lever and clutch cover are adjusted to manual spec, with sufficient slack. Any tips, or answers would be greatly appreciated.
Thanks all!
Post by willl84 on Jan 25, 2021 6:48:49 GMT -7
If you've already checked the cable and lever adjustment then It might be the oil. If the oil is a little thicker it'll drag on the clutch plates more than it should. How's the oil level as well? Overfilling the oil could net the same effect
carlos1989
Post by carlos1989 on Jan 25, 2021 7:45:16 GMT -7
Maybe a little bit if adjustment on the shifting rod aswell
Post by evitzee on Jan 26, 2021 19:37:15 GMT -7
Sounds like you need to adjust the clutch cable for free play. It's in the manual.
kaeqt
Post by kaeqt on Jan 28, 2021 8:12:48 GMT -7
If you've already checked the cable and lever adjustment then It might be the oil. If the oil is a little thicker it'll drag on the clutch plates more than it should. How's the oil level as well? Overfilling the oil could net the same effect Im currently using a fully synthetic 10W50 engine oil.. this only happens in low speed/gear 1. Doesnt happen in gear 2 onwards.. further more everything shifts smoothly
kaeqt
Post by kaeqt on Jan 28, 2021 8:13:46 GMT -7
Maybe a little bit if adjustment on the shifting rod aswell The shift rod seems fine, shift smoothly too
kaeqt
Post by kaeqt on Jan 28, 2021 8:15:15 GMT -7
Sounds like you need to adjust the clutch cable for free play. It's in the manual. The freeplay has been adjusted according to the manual, including the one located at the clutch cover.. would double check again. Hope it could be the oil causing the friction..
Post by willl84 on Jan 28, 2021 9:41:24 GMT -7
If you've already checked the cable and lever adjustment then It might be the oil. If the oil is a little thicker it'll drag on the clutch plates more than it should. How's the oil level as well? Overfilling the oil could net the same effect Im currently using a fully synthetic 10W50 engine oil.. this only happens in low speed/gear 1. Doesnt happen in gear 2 onwards.. further more everything shifts smoothly The higher gears will be less affected because the speed difference between the engine and transmission is less which would cause less drag on the clutch pack. I've had plenty of bike where if you rev while stopped with the clutch in you can feel the bike try to move slightly. It's typical of wet clutch assemblies
Post by rracerfz10 on Jan 28, 2021 14:20:47 GMT -7
Turn your adjuster at the lever alllll the way in and make the adjustment down at the adjuster by the clutch cover. Search Youtube for Revzilla shop manual Ari Henning has a video on how to do it.
mimples
Post by mimples on Jul 14, 2022 16:00:08 GMT -7
Hi all, I have been noticing that my clutch has not been disengaging fully. A few examples, 1. When coasting with the clutch in around 20kmph, if I blip the throttle I can hear and feel a clunk somewhere near the front sprocket/chain area. 2. I can hear and feel engine braking when clutched in, in first gear. When I give it a bit of throttle (still clutched in), the bike was able to coast freely. 3. I have to give it a bit of gas to get it to neutral from gear 1 when bike is hot. The bike runs fine, shift through the gears fine and smooth when riding. Am running a 10W50 oil. Clutch lever and clutch cover are adjusted to manual spec, with sufficient slack. Any tips, or answers would be greatly appreciated. Thanks all! Some mt10 from the factory shipped with faulty clutch steel ring that sits behind the clutch center and is to thick and can build a ton of heat. That heat can then transfer to the crank causing bearing failure replace it asap.
