ternity
Post by ternity on Jan 8, 2021 12:16:33 GMT -7
Hey all,
Just bought a 2020 MT10, absolutely love the bike but I need to move the gear shift lever down a bit as downshifting seems awkward.
I tried to do it myself by undoing the locknuts on the quickshifter but it wont turn - wondering if I'm doing it wrong? It was much easier on my old bike with a quickshifter...
Also will changing the length of the quickshifter after adjusting the gear shift lever height cause issues with it? As I know most QS's require a specific length to work.
Many thanks and happy riding.
Jake
Post by willl84 on Jan 8, 2021 12:36:52 GMT -7
It should just turn like any other normal turnbuckle setup would. Maybe it's corroded a bit? The QS is just a force sensor so rod length shouldn't matter at all. It just senses the push or pull on the force sensor inside it
weirdo
Post by weirdo on Jan 8, 2021 21:17:58 GMT -7
Hello, to adjust shift lever you need undo 8 mm bolt fully, pull it out and moving up or down set the hight lever
Post by willl84 on Jan 9, 2021 4:49:05 GMT -7
Hello, to adjust shift lever you need undo 8 mm bolt fully, pull it out and moving up or down set the hight lever  That's not how you're supposed to do it. That horizontal line is supposed to be aligned with the gap as shown in the picture.  Loosen the nut directly under the QS unit and then the one farther down by the shift lever. Then the shift rod should turn like any other bike
Post by hooli on Jan 10, 2021 0:55:43 GMT -7
Keep in mind that one of the locknuts has a reverse threading.
