mistico
Post by mistico on Oct 23, 2020 5:46:09 GMT -7
I have an LV decat and SP Engineering GP extreme slipon. The slipon is short and narrow so the bike is very loud. Because of this I want to try and akra slipon. Who carries the akra slipon with the black logo instead of the yellow/read/black sticker?
mistico
Post by mistico on Oct 23, 2020 7:37:52 GMT -7
Or is the sticker at least removable?
Post by evitzee on Oct 23, 2020 15:25:10 GMT -7
Sound control is done in the cat 'breadbox', once you've removed that there isn't much opportunity to quiet the exhaust. Changing to an Akra slipon won't make that much difference.
mistico
Post by mistico on Oct 23, 2020 16:15:27 GMT -7
I just fitted the stock silencer and it made a noticeable difference. The SP GP Extreme is tiny so does very little muffling. SP does not recommend this slip-on if going with a decat for that reason. They recommend their larger slip-ons but when I got it it was to be used with the stock cat.
Anyway, my question is whether the sticker on the Akra is removable or not or who has the slip-on with the black logo available.
kratosfz10
Post by kratosfz10 on Oct 23, 2020 16:54:33 GMT -7
PipeWerx will build a muffler to your specs, if you want quieter, you'll have to go with a smaller diameter inner tube and/or a longer muffler. If you want to keep the muffler short, you'll likely need to make sure the muffler you select comes with a baffle.
I currently have the 380mm R11 muffler with 60mm inner tube diameter, and it's still really loud. They also offer a 50.8mm option and different muffler lengths, I don't want to go any longer, but I may have them build one with the 50.8mm inner tube.
I know this isn't about the Akro slipon, but thought the info might be usefull.
