slangblades
Post by slangblades on Sept 28, 2020 12:55:05 GMT -7
Usually I am downshifting through the gears while holding the clutch once i'm close to stopping but still in motion. On a rare occasion I will reach a stop light and come to a full stop and then realize I only downshifted to 3rd or second gear, so then I downshift from the higher gear while completely stopped(Flat footing one leg). When I downshift while completely stopped it feels very clanky to do so. I figure the problem is the bike only wants to downshift or upshift while in motion. It only feels clanky to switch to a lower gear when I'm not in motion, otherwise it feels fine. Should I only be downshifting while in motion?
On another note, I had made a post about my brakes vibrating when I brake hard. Someone suggested I single out which of the 2 brakes vibrates. Turns out it is my rear brake. When I press it hard, and hold it there it feels like there is a vibration. I tried to make my rear tire skid a little bit but was unable to. I tried to get the tire to skid a little because I figure since I couldn't, then the vibration I am feeling might be traction control or ABS kicking in? I have the bike on Traction control 3 and Mode 3(MT-10, Mode 3 is the laziest mode). Between ABS, TC3 and M3 im not sure which of these is the reason for the rear brake vibration. I Imagine it clicks where it normally would be locking up, which to me feels like a vibration. Hoping its this and not a warped brake disc
Post by rracerfz10 on Sept 28, 2020 17:46:09 GMT -7
The vibration you’re feeling is the abs. It’s easy to lock up the rear so the abs is easier to engage. What you’re feeling is the abs pulsing it’s not a vibration.
The downshifting from 3rd gear at a stop being difficult is normal. It’s a characteristic of a sequential transmission like motorcycles have. Rocking the bike back and forth as you press down will help.
slangblades
Post by slangblades on Sept 28, 2020 22:04:40 GMT -7
Hopefully I dont come to stops in a higher gear again but if I do ill try your advice, Thanks
