ngmt10
Post by ngmt10 on Sept 16, 2020 8:52:48 GMT -7
Hi, On a recent tour my cruise control intermittently failed to activate and flashing orange light seen. I picked up a replacement oe front brake switch today but I am unsure where the wiring plug attaches. Seems to go behind radiator filler ? Question is does the fuel tank need removing ? Thanks
Post by RedAndBlack on Sept 17, 2020 9:09:39 GMT -7
Hello and welcome to the forum, there's numerous reasons why the cruise control would fail to activate and it's usually not the switch.
The most common one I've seen on here is due to a fault code usually caused by doing chain maintenance on a rear stand with the bike running.
I would check with the dealer or buy a diagnostic tool first and make sure there's no fault codes.
ngmt10
Post by ngmt10 on Sept 17, 2020 10:39:33 GMT -7
Thanks I don't run the bike on the paddock stand. I was being followed and in communication and I was advised my brake light was not always activated. I will fit the switch anyway but don't want to remove the tank of i don't need to.
jim2121
Post by jim2121 on Sept 17, 2020 12:43:58 GMT -7
Did you see if dealer would assist?
ngmt10
Post by ngmt10 on Sept 17, 2020 12:47:45 GMT -7
Yes they could fit switch at £72 per hour labour. I just wondered if it's something I could manage. I generally change break pads, oil, wheels etc
Post by RedAndBlack on Sept 17, 2020 19:48:02 GMT -7
Did the dealer check for fault codes? I mean switches go on older bikes and of course its possible, but this isn't something that typically fails on a newer bike and the oldest MT10s are what, 4-5 years old. This would certainly be a first since I've been on the board. Any fault code will render cruise control inoperative.
Other thing you could do is crack the switch open and see if anything is out of place since your brake light is being acting up. If I remember right, there's some springs or moving parts in there. Been a while since I did the cruise control mod for the R1 master cylinder.
ngmt10
Post by ngmt10 on Sept 18, 2020 0:34:31 GMT -7
No the dealer hasn't had the bike in to check. My MT10 is 4 years old now. It was odd because most days or mornings the cruise control would work fine then later in the day would not always activated (heat maybe ? It did get to 38deg air temperature and the bike was hot). Then next day it would work again.
Post by mrcdharwood on Sept 18, 2020 6:39:00 GMT -7
I made this a few months back. Give it a like and sub if it helps at all...
ngmt10
Post by ngmt10 on Sept 18, 2020 8:19:10 GMT -7
Yes thanks for that it's helpful. I still don't know where the cable connection attached and if tank needs removing though ?
Post by rracerfz10 on Sept 18, 2020 15:11:31 GMT -7
That happened to mine but it was because the rear caliper was partially seized. I bought my 2017 FZ10 as a new leftover in January 2020 so it sat for years. I’d check both end of the brakes.
ngmt10
Post by ngmt10 on Sept 18, 2020 22:52:51 GMT -7
Yes I will check all possibilities but initially want to fit this front switch. I need to know what bodywork needs removing and in which order.
Post by mrcdharwood on Sept 19, 2020 11:47:52 GMT -7
Under the right hand air scoop as if sat on the bike...
ngmt10
Post by ngmt10 on Sept 20, 2020 8:30:48 GMT -7
Fabulous thanks
ngmt10
Post by ngmt10 on Sept 22, 2020 6:36:21 GMT -7
OK so I fitted the brake switch today. If it happens again I know it's not the front switch so can then look at rear and clutch. But fingers crossed
ngmt10
Post by ngmt10 on Sept 30, 2020 5:14:49 GMT -7
I went for a long ride the other day and used cruise control plenty. It never failed to activate. I hope it's fixed but as it was intermittent I'm not 100%. Thanks
aussiemt10guy
Post by aussiemt10guy on Oct 14, 2020 6:41:31 GMT -7
Hi, recently ordered and replaced my front brake light switch. Can you explain how to open that clamp which holds the brake light switch cable and the other right hand control cable?
ngmt10
Post by ngmt10 on Oct 15, 2020 23:10:00 GMT -7
Hi I couldn't work it out so I cut through it and then used a cable tie.
mike916sp
Post by mike916sp on Dec 12, 2020 9:01:44 GMT -7
Hi all
Don't know whats going on worldwide but just had a recall notice on my 2020 MT10 in the uk.
Recall is for intermittent fault in front brake light switch that will affect cruise control
In uk Yamaha will replace free of charge
Hope that helps
duffdad
Still riding the FZ and still loving it.
Post by duffdad on Feb 25, 2021 17:42:11 GMT -7
Took my FZ 10 in for the switch recall. They said they’d need the bike for two weeks...um on. Can someone tell me the part number as I’m going to install it myself.
Thanks,
Duffdad.
Post by willl84 on Feb 25, 2021 18:32:16 GMT -7
