mclovin
Post by mclovin on Sept 13, 2020 20:51:27 GMT -7
Has anyone punched a couple of holes in the gas tank filler neck to get a little more capacity. I've seen this mod on the MT 09 forums.
Post by dkim213 on Sept 13, 2020 23:23:27 GMT -7
No
Post by rracerfz10 on Sept 14, 2020 2:33:58 GMT -7
I’ve seriously considered taking a pair of snips and cutting out as much as I could but with my luck I’d drop metal into the fuel tank.
Post by willl84 on Sept 14, 2020 8:16:07 GMT -7
If you overfill it it'll most likely all come out of the overflow hose (or into the EVAP canister if it's got it) and you'll lose it anyways.
mclovin
Post by mclovin on Sept 16, 2020 6:34:07 GMT -7
Ok, so this is a typical mod on other Yamahas. I just wanted to know if anyone has any actual real experience doing it. I'm not looking for opinions.
Post by dkim213 on Sept 16, 2020 21:18:31 GMT -7
Go do it and report back
Post by RedAndBlack on Sept 17, 2020 9:15:42 GMT -7
Got a link? Very curious about it. I can't see how gas wouldn't start to overflow into the overflow tube.
Post by willl84 on Sept 17, 2020 9:27:53 GMT -7
