Post by 0002s on Nov 6, 2016 5:24:38 GMT -7
These parts were purchased from RevZilla and are exact fit for FZ-10. You'll need front kit which comes complete with mount and pucks. Rear kit comes complete with left and right side mounts and pucks. The frame slider mounts come in a kit with right and left side mounts. The pucks are sold individually so you will need two. The Pit Bull pins come in kit with two pins. Tools required are 19mm box wrench, 10,8,6mm allen sockets, 3/8 ratchet, extender bar, torque wrench for frame mounts (32 ft lb spec) and some blue loctite (optional). The front and rear mounts are straight forward installs. The front can only install one way and takes less than ten minutes to install. The rear mount are left and right and can only install one way. The rears take less than 10 minutes. The frame mounts take around 30 minutes to install. The directions are ok at best. The longer mount is left and the shorter mount is right. The left bolt is 10mm to remove and right is 8mm. Be careful threading the supplied bolts as they could cross thread easily. Hand fit them first. Tighten mounts, 10mm, to factory 32 ft lb specs with torque wrench. Install pucks. Pit Bull pins take less than 10 minutes to install and use a 6mm allen socket. Be careful not to over tighten. I broke a bolt (may have been defective). Replacement bolts are 6Mx1 and are available at any hardware store. The cost was around $230 shipped for everything. Install looks clean and factory. Worth it for piece of mind imho.
pickled1st
Post by pickled1st on Apr 4, 2018 12:38:20 GMT -7
Sure 32 lb/ft is correct? I'm seeing 51 lb/ft in the manual. Its a Euro manual but lb/ft in this case wouldn't change. Maybe they want their engines more secure across the pond, haha. I suggest re-torquing.
