popedizzle
Post by popedizzle on Aug 4, 2020 9:35:18 GMT -7
Bought my bike used (2017) and previous owner had changed out front turn signals already.
Went out to work on the bike and noticed that only the right side lights will hyper flash. Left and hazards work fine.
I modded the exup valve (left servo attached and removed cables) earlier that day if that means anything.
Any ideas?
dutchmt10
Post by dutchmt10 on Aug 4, 2020 10:29:36 GMT -7
I’ve had this happen on my MT-07 a few times. They would either stay on continuously or flicker really fast. Pretty sure it was the relay that is used for the aftermarket LEDs that was broken.
popedizzle
Post by popedizzle on Aug 4, 2020 10:33:08 GMT -7
I’ve had this happen on my MT-07 a few times. They would either stay on continuously or flicker really fast. Pretty sure it was the relay that is used for the aftermarket LEDs that was broken. I did notice that the rubber holding the front right signal was broken so I super glued it together. I had to slightly tug in the light to get the bottle in between the two pieces. Maybe this knocked something loose. In your opinion I'm better off getting new lights?
dutchmt10
Post by dutchmt10 on Aug 4, 2020 10:40:28 GMT -7
I don’t think the light itself is broken. I’m no electrical expert but I think my dealer once told me that you need those little relays when you change your blinkers to LEDs. They prevent the fast blinking on them. So I’m pretty positive it is the blinker relay. It should be quite cheap to fix.
popedizzle
Post by popedizzle on Aug 4, 2020 11:22:47 GMT -7
The right side didnt always flash faster. Any idea where I can get the part, part number, or where it's at? I've tried searching around and no luck.
dutchmt10
Post by dutchmt10 on Aug 4, 2020 22:32:09 GMT -7
Unfortunately I don’t know the part number or name. I guess your best bet is to go to your local dealer and ask them. They should be able to tell you and will probably even change the part for you for only a few bucks.
