jdm74
Post by jdm74 on Aug 4, 2020 8:32:50 GMT -7
Anybody have one of these slip ons with the stock cat box still in place? Curious how they think it sounds and what their thoughts are on it. I'm thinking about pulling the trigger on it as I like the appearance and the fact that even the SS version is lighter than the stock Ti can.
I was able to find a sound clip on Leo Vince's website and it seems to sound pretty good but would like an impartial opinion.
wingnut03
Post by wingnut03 on Aug 24, 2020 18:56:46 GMT -7
Hi,I put one of these on my 2020 mt10 and my 2017 fz10,I like how it sounds nice tone not to loud but wide open you hear it,plus good bang for your buck.
Post by mrcdharwood on Aug 25, 2020 6:05:36 GMT -7
Did have. Too loud for me with the LV link pipe. Now have R1 cat and AR can.
jdm74
Post by jdm74 on Sept 4, 2020 16:35:27 GMT -7
I did end up pulling the trigger on it and I'm not disappointed. It sounds great!
thalex
Post by thalex on Oct 13, 2020 9:40:27 GMT -7
I like how compact these are. Did you run it with the decat or on it's own?
jdm74
Post by jdm74 on Oct 18, 2020 16:48:19 GMT -7
I run it on its own with the EXUP valve wired open and a 2WDW tune. Sound is perfect in MHO.
oldguymadspeed
Post by oldguymadspeed on Aug 4, 2021 7:33:03 GMT -7
I run it on its own with the EXUP valve wired open and a 2WDW tune. Sound is perfect in MHO. Do you have a before and after sound clip. I put a cheaper one 9n mine and it way to loud even with the cat. To much drone.
jlapaglia
Post by jlapaglia on Aug 4, 2021 9:10:58 GMT -7
I run it on its own with the EXUP valve wired open and a 2WDW tune. Sound is perfect in MHO. Do you have a before and after sound clip. I put a cheaper one 9n mine and it way to loud even with the cat. To much drone. Do you have the cat on still? I put a lv-10 on (everything else stock) and I don’t have any drone. At idle it is only a little louder than stock. Once moving and the valves open it is definitely noticeable and sounds good. I’ll have to try to get a video of it while riding because at idle it doesn’t do much.
oldguymadspeed
Post by oldguymadspeed on Aug 4, 2021 12:10:01 GMT -7
Do you have a before and after sound clip. I put a cheaper one 9n mine and it way to loud even with the cat. To much drone. Do you have the cat on still? I put a lv-10 on (everything else stock) and I don’t have any drone. At idle it is only a little louder than stock. Once moving and the valves open it is definitely noticeable and sounds good. I’ll have to try to get a video of it while riding because at idle it doesn’t do much. Yes I have the Cat on and the exhaust valve wired open. Also the ECU has been flashed. I decided to try something different today with the stock exhaust off and nothing else on. It sounded pretty good. Low rumble and only a bit loud when taking off. Otherwise at speed it was decent. So I Put on a Chrome tip for now. Looks kinda good but low budget. I need to figure out if the Leo Vince sound is similar and if spending a few hundred to get the look is worth it.
subkrato
Post by subkrato on Aug 7, 2021 17:20:08 GMT -7
I have the Leo and stock exhaust. It’s a good balance of loud but not too loud. The color of the pipe matches the headers nicely, but I want louder and the look of an aftermarket can. Overall, better than stock. Message me and I can send a video.
oldguymadspeed
Post by oldguymadspeed on Aug 13, 2021 16:06:25 GMT -7
I was actually looking at the Leo Vance Slip on. The LV10. Im gonna keep the Cat for now.
Post by sdshawn on Sept 30, 2021 17:52:06 GMT -7
I wasn't sure witch thread to put this in but this one seemed to fit so I've been searching for the perfect sound with the stock cat with out spending the big bucks and then being disappointed. So my latest knock off purchase sounds really good, it's a dominator knock off and so far sounds great on the stand but will see after my next ride. Then once I get close to what I think is where I want to be then I'll get the real thing. Also if anyone else is interested in trying out the last 2 that sounded great also I'll send them out to you for trial free but you cover shipping. The problem is adapters the don't fit by a few mm I had to make shift the to get them to work. You can pm me to get the opening I don't know off the top of my head but I will measure if interested.
pnwmt10
Post by pnwmt10 on Mar 27, 2022 13:09:18 GMT -7
Did have. Too loud for me with the LV link pipe. Now have R1 cat and AR can. Do you know if the Austin Racing fits on the decat? I have both Leo's and need something louder than the lv10
