fester999
Post by fester999 on May 10, 2020 9:39:06 GMT -7
I'm new to this forum. My 2016 MT10 has done roughly 7000 miles. It has just thrown up 4 codes. Starting issues, stalling issues, cruise switch faulty and the worrying one intake manifold throttle valve motor. The bike is running fine. My mechanic can't clear the codes so I'm waiting for main dealer to open. I realise that the cruise switch could be due to the aftermarket levers. Stay safe. Fester
Post by evitzee on May 10, 2020 18:44:08 GMT -7
Aftermarket levers shouldn't cause a problem. Is the plunger switch depressed on the clutch side? If so it isn't the lever, something else is going on.
fester999
Post by fester999 on May 10, 2020 23:17:05 GMT -7
Thanks I'll have a look. I don't use the cruise control. I hope the main dealer can reset the codes and it's not a massive bill.
