lblack
Post by lblack on Oct 19, 2023 3:21:34 GMT -7
Neutral indicator intermittently on or off bike won't start with out clutch in and side stand up. All ready changed side stand switch.
Post by willl84 on Oct 19, 2023 4:27:35 GMT -7
Neutral indicator intermittently on or off bike won't start with out clutch in and side stand up. All ready changed side stand switch. N indicator is driven by the gear position sensor which is right behind the front sprocket pointing up from the engine case and has a blue connector. Might have to consult the service manual to see what the neutral voltage is supposed to be. Might be a bad sensor or something up with the wiring.
