jet
Post by jet on May 1, 2020 1:26:53 GMT -7
Hi All, First question on the forum! Proud owner of a brand new MT10 SP I'd like to install crashpads from Gilles Tooling available Here
but there isn't any details about the torque. I've checked in the service manual and I've found 70nm but I'm not 100% sure and I'd like to have your opinion. This is where the crashpads are meant to be installed to give you an idea :
and this is the details about the torque specs found in the mt10 service manual : Cheers ! (sorry if my english isn't perfect (frenchie ) , let me know if the text above doesn't make sense)
Post by RedAndBlack on May 1, 2020 18:45:04 GMT -7
Welcome to the forum. You're english is perfect! Sorry I don't know the answer, but wanted to welcome you to the forum.
sergioc22
Post by sergioc22 on May 1, 2020 19:24:32 GMT -7
I hv used those totque specs to install mine, not Gilles other brand
jet
Post by jet on May 2, 2020 12:18:32 GMT -7
Thanks mate ! Really appreciate ! I'll make sure to upload a pic of my bike in the appropriate post Thanks that's what I ended up doing, perfect !
yourname2221
Post by yourname2221 on May 3, 2020 9:13:24 GMT -7
I got T-Rex sliders myself and they didn't come with torque specs either so I looked around and saw that Womet-Tech sliders were rated for 38 ft lbs. I emailed Trex asking since I had another question anyway, but I'm sure 50 ft lb is adequate.
Post by rracerfz10 on May 3, 2020 21:00:54 GMT -7
On my Crazy Iron crash cage all the directions were in Russian so I just went with the factory torque specs for those engine bolts of 51ft/lbs. They are the same bolts you’re asking about.
jet
Post by jet on May 4, 2020 0:04:02 GMT -7
Perfect thanks !
