kruik013
Post by kruik013 on Apr 5, 2020 8:08:55 GMT -7
Hello, I recently bought a 2nd hand MT10 and today I discovered a coolant leak. (The seal behind the manifold on the engine) Who had the same problem and repaired it themselves? What did you do with the oil cooler, did you just flip it over to access the bolts from the coolant pipes? fz10.org/thread/2212/coolant-leak it's just like this. Thanks!
Post by mrcdharwood on Apr 7, 2020 6:55:52 GMT -7
I removed it all together for a full system drain and refill after replacing the part. Make sure you order the correct part as they superseded it to a different material. While your at it replace the seals at the water pump end too as its all off anyway. Unless you're lucky you'll need to remove the headers too. This is because the "flow" pipe from the water pump needs to be removed and a bolt for that sits right behind the headers 🙈. I did manage to get a cut down Allen key in the bolt hole bit it was too seized to get it off and rounded off. You may be lucky though.
