chesterburnet
Post by chesterburnet on Mar 14, 2020 13:38:29 GMT -7
Does anyone have a way to get the warning decal off the tank without scaring up the paint?
Post by dkim213 on Mar 14, 2020 13:52:01 GMT -7
Peel it and then use goof off
northsouth
Post by northsouth on Mar 14, 2020 16:28:59 GMT -7
warm it up with a hair dryer for a little bit first. Softens the glue and it will peel right off without having to use anything to remove the sticky crap.
Post by evitzee on Mar 14, 2020 17:01:54 GMT -7
Shiny or matte paint? On a gloss finish use heat and your fingernails to get it off. Then Goo Gone. Trickier on a matte finish, you have to be very careful not to scratch the paint.
Post by RedAndBlack on Mar 14, 2020 20:27:34 GMT -7
Hair Dryer method for sure. Even better if you let it sit in the sun for a bit.
Goo Gone or WD-40 to get the remnants.
Post by Deleted on Mar 15, 2020 22:13:20 GMT -7
I have the more delicate matte paint, and no issues with heat and finger nails. Then WD-40 for the residue, followed with a wax job (I did the entire bike). I'd NEVER use Goof Off on any paint or plastic; that thing is nasty. Goo Gone is effective too, but it requires more rubbing, so I only use it to remove airbag sticker residue from sun visors. By the way, I removed ALL stickers (except the VIN one), reflectors, and visible assembly paint on day 1 .
vk
Post by vk on Mar 16, 2020 6:06:57 GMT -7
Hair dryer works great bro. Got the matte black and it was fine. Just be patient when warming it up and start at a corner. Once started just go slow and reheat as needed. Works for the swing arm sticker as well.
chesterburnet
Post by chesterburnet on Mar 17, 2020 21:53:23 GMT -7
Hair dryer works great bro. Got the matte black and it was fine. Just be patient when warming it up and start at a corner. Once started just go slow and reheat as needed. Works for the swing arm sticker as well. Good advice. I followed and it worked like a charm.
