Post by rracerfz10 on Feb 24, 2020 18:48:07 GMT -7
I didn’t find anything by searching so my apologies if this has been covered. Is the R1 rear sprocket a direct fit to the FZ-10’s hub? I want the 2 tooth smaller sprocket for a few reasons. Slightly better highway mileage, little longer wheelbase, and less wheelie prone. Thanks in advance for the help.
wodger63
Post by wodger63 on Feb 25, 2020 12:52:17 GMT -7
Different sprocket, 530 pitch, with 5 mounting studs IIRC. From my research the options are, aluminum either in 520 (new chain and front sprocket) or 525 pitch. Supersprox do a custom Stealth 525 sprocket in any tooth count you like. I could find plenty of steel sprockets with more teeth than standard but none with less, except for Supersprox. There might be more options out there, that's just what I could find.
Post by hooli on Feb 25, 2020 12:54:33 GMT -7
The sprockets for the R1S will fit. The ones for the R1/R1M with the magnesium wheels will not work.
Post by rracerfz10 on Feb 25, 2020 17:57:49 GMT -7
That’s exactly what I needed to know. Thanks!
wodger63
Post by wodger63 on Feb 25, 2020 18:18:09 GMT -7
That’s exactly what I needed to know. Thanks! Just be aware that the 6 stud R1 sprocket is a 530 pitch.
Post by rracerfz10 on Feb 25, 2020 18:24:53 GMT -7
Doesn’t the FZ10 use a 530 chain?
wodger63
Post by wodger63 on Feb 25, 2020 19:38:39 GMT -7
Doesn’t the FZ10 use a 530 chain? It's a 525VZ, from the service manual.
Post by rracerfz10 on Feb 28, 2020 2:22:42 GMT -7
Ah ok. Well then is there a comparable rear sprocket with two less teeth out there is a better question lol
pc1978
Post by pc1978 on Feb 28, 2020 6:30:44 GMT -7
Post by rracerfz10 on Feb 29, 2020 0:12:59 GMT -7
Perfect thanks!
