kratosfz10
Post by kratosfz10 on Jan 24, 2020 18:03:39 GMT -7
I am changing to the PipeWerx High-Level exhaust, so I will be selling my current Hindle 3/4 exhaust system. I purchased the Hindle 3/4 Evolution system from 2WDW as a package along with their ECU flash. I purchased the Hindle SuperSport (pictured on the bike) muffler through 2WDW later to help lower the DB's. Cost of the 3/4 system with Evolution muffler was $618 and the SuperSport muffler was $367. I'd like to get $600 for everything, may consider selling with one of the mufflers for $450. I can also provide closer pics of any of the parts if interested. I also have the db killer for the Evolution muffler. Both mufflers are 14" instead of the standard 12" length. Located in Huntingburg, IN 47542 Local pick-up is best, but will ship. PM if interested.
sfbayrider
Post by sfbayrider on Feb 17, 2020 4:14:17 GMT -7
so.. is it still ear bleeding loud, with the bigger can ?
any chance of doing a short video of stock vs hindle with bigger can?
kratosfz10
Post by kratosfz10 on Feb 17, 2020 6:05:58 GMT -7
so.. is it still ear bleeding loud, with the bigger can ? any chance of doing a short video of stock vs hindle with bigger can? I just got done installing the PipeWerx exhaust and have the ECU out of the bike to send back to 2WDW to get re-flashed. If we get another nice day after I get the ECU back, I may swap out the exhausts and make videos, but you could likely find videos on YouTube of stock and Hindle. Both mufflers are the same size, the difference is the core size, the Evolution has a 2.25" core, the SuperSport has a 2" core and the Stealth has a 1.75" core. Both mufflers are 14" long instead of the 12" standard length. I'll be honest, if you wear a full-face helmet and don't/won't wear earplugs, I don't think you would be happy with it. If you don't wear a helmet, then you should be fine. The CP4 has a deeper tone and in the lower RPM it would drone inside the helmet, when I rode without my helmet, it was fine. This could also just be due to the helmet itself (Arai Signet Q), as I don't see many other posts about droning. You could always put the db killer in the Evolution muffler, but then it doesn't sound much different than stock.
