theestate
Post by theestate on Jan 23, 2020 19:20:21 GMT -7
Compared to KTM 1290 Adventure. This assume enough power to hit redline and the engine is not governed. RPM column shows engine speed after shift from previous gear. Up shift always occurs at redline.  Ride on
theculturalattache
Post by theculturalattache on Jan 24, 2020 17:11:34 GMT -7
The interesting thing for me there is the top speed in 1st,79 MPH.
Current R1 does just over 100MPH in first,quite a difference.
Post by Deleted on Jan 25, 2020 10:27:05 GMT -7
Wish the MT-10 had the gearing of that Super Adventure, with a shorter 1st, taller 6th, and better gear spread all around. But a better comparison would have been the Super Duke, which I'm afraid it probably also has all-out sport gearing. At least Yamaha did a good job of matching drag with power, to top out at around 160 at redline (the numbers above are close enough), but 6th is too short for good highway fuel economy, which is really needed with only a 4.5-gal tank. Too short range is the only real criticism I have of my bike. Just 1/2-gal more would have made it just about perfect  .
chesterburnet
Post by chesterburnet on Jan 28, 2020 22:10:15 GMT -7
Wish the MT-10 had the gearing of that Super Adventure, with a shorter 1st, taller 6th, and better gear spread all around. But a better comparison would have been the Super Duke, which I'm afraid it probably also has all-out sport gearing. At least Yamaha did a good job of matching drag with power, to top out at around 160 at redline (the numbers above are close enough), but 6th is too short for good highway fuel economy, which is really needed with only a 4.5-gal tank. Too short range is the only real criticism I have of my bike. Just 1/2-gal more would have made it just about perfect  . I agree about the tank. Just a half gallon more. I had mine up to 135 mph on Saturday. it had a lot more left.
