superspirit
Post by superspirit on Jan 3, 2020 17:31:08 GMT -7
I'm running the motodynamics integrated taillight, has the same options as the blaster x but half the cost. I also went to a smaller turn signal that would fit with the bags however they cannot be seen when the bags are on. All in all I'm happy with the outcome.
vstate60
Post by vstate60 on Jan 4, 2020 18:42:45 GMT -7
Uknixter, you'll have to excuse elptxjc, he isn't the brightest bulb on the forum. Looking at your previous posts, it seems you are in SoCal, have a Vagabond fender eliminator, and probably don't think an integrated tail light is a safety hazard. Good luck and happy New Year. Thank you. Just....thank you.
vstate60
Post by vstate60 on Jan 4, 2020 18:47:27 GMT -7
I have the Blaster X integrated taillight. The blinkers are a very Bright orange and the brake light will flash rapidly when the brake is applied. The tail light is also programmable. Honestly the Blaster X is very safe and made in the U.S.A. I least it would be a safety upgrade and a very good solution to the mounted bags. If I did not think it was safe I would not have it on my FZ 10. Link: www.customled.com/collections/integrated-led-tail-lights-for-motorcyclesHave same integrated brake/signal and it’s hard to argue against it as a huge safety upgrade. The programmable flashing/bright LEDs/ sequential signals/visibility is just perfect. One of the ‘nervous until I did it 100 miles in’ type upgrades. I’d rank it above nearly anything else upon initial purchase, in regards to DIY upgrades. And what’s the point of a fender eliminator if you don’t get rid of those ginormous blinkers?
