krisby
Post by krisby on Dec 5, 2019 2:22:28 GMT -7
Post by Deleted on Dec 5, 2019 14:45:57 GMT -7
It looks that way to me too, but only a low shot from behind would give you a better estimation. As an FYI, if you don't carry a passenger, and not a heavy person, the long peg feelers would touch much earlier than needed. That exhaust might not touch before the long stock feelers. But if you remove them (or replace them with shorter ones, like I did, to avoid touching hard parts first), then it'd be a lot more likely to touch. Actually, ANY exhaust could touch, but what matters is where . Good luck.
vstate60
Post by vstate60 on Dec 5, 2019 22:50:27 GMT -7
I run the M4 Carbon 3/4 system that looks very similar in size and shape to the aforementioned setup and have never touched it. I won’t brag about ‘cornering low, bro!’ But if I haven’t scraped the exhaust yet, it isn’t something to worry about. If you’d like for reference I’ll post a pic of my exhaust—does look about the same, though.
Post by Deleted on Dec 6, 2019 0:41:20 GMT -7
I have this exact system on my bike. I haven't scraped the can at high lean angles on the track or street.
I am quite tall so my knee is down before any hard parts.
The system is also very loud. keep the baffle in. Without the baffle it hurts your ears even with ear plugs in. Baffle in is nice and loud but just takes that sharp edge off. Shoots nice flames as well as shotgun like blasts if you keep the AIS enabled.
krisby
Post by krisby on Dec 6, 2019 18:58:37 GMT -7
I have this exact system on my bike. I haven't scraped the can at high lean angles on the track or street. I am quite tall so my knee is down before any hard parts. The system is also very loud. keep the baffle in. Without the baffle it hurts your ears even with ear plugs in. Baffle in is nice and loud but just takes that sharp edge off. Shoots nice flames as well as shotgun like blasts if you keep the AIS enabled. Awesome, thanks for that im 6' 1'. The flames look awesome too, I always ride with ear plugs in as I commute daily on the motorway. Do you have the 250 or 320mm length can?
krisby
Post by krisby on Dec 6, 2019 19:00:35 GMT -7
I run the M4 Carbon 3/4 system that looks very similar in size and shape to the aforementioned setup and have never touched it. I won’t brag about ‘cornering low, bro!’ But if I haven’t scraped the exhaust yet, it isn’t something to worry about. If you’d like for reference I’ll post a pic of my exhaust—does look about the same, though. That would be great if you could post some pics too, I do like the look of the M4 also. Im trying to decide between these two exhausts as they are significantly cheaper than any other cat+end can system in New Zealand
Post by Deleted on Dec 8, 2019 22:05:21 GMT -7
I have this exact system on my bike. I haven't scraped the can at high lean angles on the track or street. I am quite tall so my knee is down before any hard parts. The system is also very loud. keep the baffle in. Without the baffle it hurts your ears even with ear plugs in. Baffle in is nice and loud but just takes that sharp edge off. Shoots nice flames as well as shotgun like blasts if you keep the AIS enabled. Awesome, thanks for that im 6' 1'. The flames look awesome too, I always ride with ear plugs in as I commute daily on the motorway. Do you have the 250 or 320mm length can? I think its the 320mm but not entirely sure. I can measure it when I get home today. Cheers
mattwild27
Post by mattwild27 on Jul 30, 2021 18:39:00 GMT -7
I have had it for a few years on mine and if it’s not too late don’t buy it. I scraped in cornering and blew a hole in the side of the carbon exhaust. Also the link pipe will not work for any other slip on because the can is lower than oem mounts.
Post by heathhudnall on Aug 18, 2021 16:56:16 GMT -7
Bike hase R1M Ti headers on it as well now. This video is old, but it's all I got to show the pipe. It's the 250mm, I love it. Best looking pipe for the 10 in my opinion.
