csmith52016
Post by csmith52016 on Oct 27, 2019 0:58:23 GMT -7
I am thinking about replacing my rubber lines and throttle cables, but I’m not sure about length and where to buy from. My worry is that, since I added two inch bar risers, the lines and cables that say fit an FZ-10 will be too short.
mtneer
Post by mtneer on Oct 27, 2019 13:06:48 GMT -7
Contact Spiegler USA, they can make you a custom set of lines, Motion Pro should have or can make you longer throttle cables.
kratosfz10
Post by kratosfz10 on Oct 27, 2019 16:42:40 GMT -7
I am thinking about replacing my rubber lines and throttle cables, but I’m not sure about length and where to buy from. My worry is that, since I added two inch bar risers, the lines and cables that say fit an FZ-10 will be too short. So you have already installed the risers and the stock cables/lines are too short? Check out Spiegler for the brake lines, they will make the top line whatever length you want, you'll just have to call to place the order since it will be custom. spieglerusa.com/brakes/brake-lines-accessories-tools/cycle-brake-line-kits/yamaha-fz-10-abs-brake-line-kit-19930.htmlMotion Pro should be able to make your throttle/clutch cables if you need them longer, but you may have to send your stock cables to them so they can duplicate and extend. www.motionpro.com/c/cables
csmith52016
Post by csmith52016 on Oct 28, 2019 4:31:59 GMT -7
Thanks for the advice. I never knew how expensive brake lines could be. $250 just seems like robbery.
Post by hooli on Oct 28, 2019 7:26:29 GMT -7
Core Moto is also a viable option for custom length brake hoses. They worked with me when I requested different length hoses to combine with my ABS delete and Woodcraft top plate clip-on bars. More color choices than other aftermarket brake hoses manufacturer.
