heavypaw
Post by heavypaw on Sept 20, 2019 9:59:12 GMT -7
Hello everyone! I'm new from asia. I'm considering to buy the MT-10. But my height only 5 feet 6 inches ( I have thought about going to a showroom and take a sit, but it really far from my house. So, I created a post to ask if I my legs could comfortably when I sit on this bike. Hope I didn't bother you a lot. Thanks.
mt10cp4
Post by mt10cp4 on Sept 20, 2019 11:40:47 GMT -7
You’ll be fine. I’m five foot five and I am very comfortable when I rode it during demo ride. Obviously I am tip toe on stand still but it is not a problem at all.
fastfed
Post by fastfed on Sept 20, 2019 17:22:04 GMT -7
you would be able to ride a 450 dirtbike no problem
the trick is to just lean over a little more at a stop, not a big deal
fastback89
Post by fastback89 on Sept 20, 2019 18:08:36 GMT -7
I'm 5'7" with no issues. not quite flat footed at a stop but you should be fine
yzfgsx
Post by yzfgsx on Sept 20, 2019 18:42:49 GMT -7
I am 5‘6“ and have no problem, I’m not far from being flat footed.
Post by Deleted on Sept 20, 2019 21:51:30 GMT -7
Hey brother, you stated the wrong dimension. Ha ha. You can be 5'6", but what could be a problem is your INSEAM, not your overall height. I have 31" inseam (5'10"), and wouldn't feel safe with any less than that... but I use sporty/thin-soled boots. Ans also got the slightly higher comfort seat (a must IMO). You could always make up about 1" in height by using thick-soled boots. A last resort is lowering the suspension, but I always recommend against that. Good luck.
heavypaw
Post by heavypaw on Sept 21, 2019 1:19:45 GMT -7
Thanks so much, you all gave me the motivation.
twistydave
Post by twistydave on Sept 21, 2019 8:20:09 GMT -7
I have a 29 inch inseam. Yes I ride the stock but tip toe, can’t throw my leg over the sea easily and that is a bit of a challenge. This means I have to be more cautious stopping, U turning , picking a place to put the kick stand down. While in motion it’s no problem. Mt buddy has a 2016 BMW RS it’s seat height can be adjusted and boy it make a big difference. Having a shorten inseam just makes us work a bit harder. If you even have to ask this question I’d recommend the fz7 and you will flat feet.
daveinwoodland
Post by daveinwoodland on Sept 21, 2019 10:00:59 GMT -7
chesterburnet
Post by chesterburnet on Dec 29, 2019 21:30:57 GMT -7
I was gonna try and borrow some $ here but I can see you're all short.
northsouth
Post by northsouth on Dec 30, 2019 16:24:50 GMT -7
I was gonna try and borrow some $ here but I can see you're all short. 😂
