Post by hooli on Sept 16, 2019 10:24:17 GMT -7
May I ask what exactly you find lacking on the stock suspension? In which weight range in full gear are you (150-170, 170-190, etc)? What pushed you to those 2 brands? And do those GP cartridges retain the stock adjustments? For sure start a new thread when you get them, with pros and cons, but for now just curious on your motivation to change. Thx. I weigh 220lbs fully geared up. The stock parts are fine for street use but when pushed hard on the track, the shortcomings are a bit evident; springs are on the soft side and damping could be more effective. I was considering Ohlins parts (had great success with them in the past, and it's a proven brand with a substantial knowledge base). But Stoltec Moto has worked with both Penske and GP Suspension in developing a shock and fork cartridges designed specifically for the FZ/MT-10. For me at least, quality suspension is at the top of my mod list. I would easily put it before a decat/end can package.
For the meantime though I will continue to use my standard parts for both street and trackdays through the end of the year.
