drozboyz
Post by drozboyz on Sept 4, 2019 9:02:24 GMT -7
Anybody have these installed on their mt-10?
drozboyz
Post by drozboyz on Sept 7, 2019 9:27:50 GMT -7
Following
kratosfz10
Post by kratosfz10 on Oct 26, 2019 20:49:45 GMT -7
I have the Gilles-Tooling risers. The forward/backward adjustability is really nice. The one thing to note is that the pedestal and spacers it comes with only put it at stock height. I ended up finding another set for sale on ebay for half the price (was not specifically for the FZ-10, but had the same spacers). I added two spacers to each side for a total of 4 per side. So I now have my bar adjusted 25mm back and 10mm higher, which is all you can do without worrying about lengthening you front brake line and lengthening or re-routing your right hand switch wiring. I'm 5' 9" with a 32" inseam and this is pretty much perfect for me. I tried to get another set of spacers from Gilles, but they said they didn't recommend going any higher due to the cable lengths, which is obviously not an issue for just adding 10mm.
Another thing to note: The bolts that came with the set I bought on ebay were longer than the ones in the kit specifically for the FZ-10, so I was able to add the 10mm in height. The bolts in the FZ-10 kit will allow you to go 5mm higher, maybe just a tad more, but if you try to go 10mm, the nut may not thread all the way on the bolt before it gets tight.
dashiznit1
Post by dashiznit1 on Dec 16, 2019 10:07:07 GMT -7
I bought a set of Rox Risers and the cables are far too short to work with them. I'm currently trying to find a way to get enough slack to install them and when/if I do I'll make an installation write-up and review for them.
