glmt10
Post by glmt10 on May 27, 2019 18:55:01 GMT -7
Hello there. I've had my MT-10 for a few weeks now and am very much loving it. I sold my GSXR-750 since it was only being used for track days and I wanted something that was more comfortable to ride on the street and still be able to do the occasional track event. Thus far, I've made just a few modifications for practicality (frame sliders, upgraded horn, swingarm spools/sliders, and a larger sidestand foot).
The next potential mods on my list are an ECU flash, seat upgrade and possibly an exhaust.
Cheers!
theculturalattache
Post by theculturalattache on May 28, 2019 3:01:33 GMT -7
Welcome and glad your enjoying the bike.
What colour you gone for and got any pics?
Cheers.
Post by RedAndBlack on May 28, 2019 18:07:47 GMT -7
Welcome to the forum!!! Where in Cali are you from?
glmt10
Post by glmt10 on May 29, 2019 22:18:35 GMT -7
Hi there. I'm on the central coast about 35 minutes north of Santa Barbara. I got a 2018 model in blue/black and got a good price since it's last year's model.
daveinwoodland
Post by daveinwoodland on May 30, 2019 9:21:11 GMT -7
Wave from Northern California now that the rain has stopped finally. I'm am curious on your horn upgrade what you decided to use and where you mounted it? Thanks!!
glmt10
Post by glmt10 on May 30, 2019 19:52:42 GMT -7
Wave from Northern California now that the rain has stopped finally. I'm am curious on your horn upgrade what you decided to use and where you mounted it? Thanks!! Hi there. I bought a Denali Soundbomb Mini. Even though it's "mini" it's a fair bit larger than the stock horn and hangs down from the lower triple clamp a bit in the stock location. It doesn't interfere with the fork stroke or turning the forks though, and it's significantly louder than stock. Only $30 and plugs into the existing horn wiring without a custom harness. If the current location starts to become an issue, I'll have to look around for an alternate mounting spot.
kristianmartin
Post by kristianmartin on Jan 23, 2020 11:20:47 GMT -7
Nice. I just moved into SB! 35 miles north...what's that, Solvang? Anyway, welcome (belated). Maybe we could ride together sometime!
vstate60
Post by vstate60 on Jan 23, 2020 11:32:08 GMT -7
Wave from Northern California now that the rain has stopped finally. I'm am curious on your horn upgrade what you decided to use and where you mounted it? Thanks!! Hi there. I bought a Denali Soundbomb Mini. Even though it's "mini" it's a fair bit larger than the stock horn and hangs down from the lower triple clamp a bit in the stock location. It doesn't interfere with the fork stroke or turning the forks though, and it's significantly louder than stock. Only $30 and plugs into the existing horn wiring without a custom harness. If the current location starts to become an issue, I'll have to look around for an alternate mounting spot. Welcome to the forum! I bought the full sized Denali Soundbomb and I have dug into it yet but it’s not looking good for going on our bike. Maybe I should return it and go with the mini...
glmt10
Post by glmt10 on Jan 23, 2020 21:52:58 GMT -7
I'll try to remember to get a photo of the horn installed when I get home. It looks a little goofy, but it doesn't impede fork travel or turning either direction.
Post by Deleted on Jan 25, 2020 11:03:53 GMT -7
Hi there. I bought a Denali Soundbomb Mini. Even though it's "mini" it's a fair bit larger than the stock horn and hangs down from the lower triple clamp a bit in the stock location. Only $30 and plugs into the existing horn wiring without a custom harness. Hey, so you didn't use a relay??? And does it work fine? I'd assume that horn would blow the stock fuse in a hurry, since its amperage is much higher than stock. Not touching the factory wiring was nice, and smart, but not sure those tiny wires are up for that job. Looking forward to your pictures of it, and your comments on the wiring . I was thinking of getting one, but having to install a fuse box and relay are stopping me from doing it .
Post by dkim213 on Jan 25, 2020 12:55:51 GMT -7
Hi there. I bought a Denali Soundbomb Mini. Even though it's "mini" it's a fair bit larger than the stock horn and hangs down from the lower triple clamp a bit in the stock location. Only $30 and plugs into the existing horn wiring without a custom harness. Hey, so you didn't use a relay??? And does it work fine? I'd assume that horn would blow the stock fuse in a hurry, since its amperage is much higher than stock. Not touching the factory wiring was nice, and smart, but not sure those tiny wires are up for that job. Looking forward to your pictures of it, and your comments on the wiring . I was thinking of getting one, but having to install a fuse box and relay are stopping me from doing it . Quit assuming and do some reading: www.revzilla.com/assets/0002/0795/denali_soundbomb_mini_horn.pdf
gunnar
fabbin stuff...
Post by gunnar on Jan 25, 2020 14:42:06 GMT -7
That's assuming he can turn a wrench and plug two wires in...I'm not so sure.
Post by Deleted on Jan 25, 2020 22:15:17 GMT -7
Sorry to get your panties in a wad. But next time put the freaking link first, and I don't have to assume . Anyway, thought you were talking about the Soundbomb AIR HORN linked below, not that electric one I hadn't seen before... and not interested in. So never mind.
Post by dkim213 on Jan 25, 2020 22:16:38 GMT -7
Sorry to get your panties in a wad. But next time put the freaking link first, and I don't have to assume . Anyway, thought you were talking about the Soundbomb AIR HORN, not that electric one I hadn't seen before, and not interested in. So never mind . Thanks for the apology, idiot.
Post by Deleted on Jan 25, 2020 22:18:32 GMT -7
Thanks for the apology, idiot. You don't deserve one, ahole. Ignored.
Post by dkim213 on Jan 25, 2020 22:20:24 GMT -7
That's assuming he can turn a wrench and plug two wires in...I'm not so sure. I always thought some of you guys were too harsh on that guy. I was definitely wrong.
gunnar
fabbin stuff...
Post by gunnar on Jan 26, 2020 6:07:37 GMT -7
The mods should remove his blocking option so he is forced to read about his fuck ups, that is the only way he will learn...F him.
glmt10
Post by glmt10 on Jan 29, 2020 21:31:50 GMT -7
Sorry for the delay, here's a few photos of the Soundbomb mini. It's easy to wire up since it doesn't need a relay, but it definitely is more visible (and more importantly, LOUDER) than the stock horn.
jacoby
Post by jacoby on Jan 30, 2020 6:33:42 GMT -7
Jeez that looks bad
vstate60
Post by vstate60 on Jan 30, 2020 19:36:26 GMT -7
Like you’d even notice it without the zoomed in pictures...definitely think it’s worth it. Are you related to exclyptix or whatever his name is?
