fattybolatty
Post by fattybolatty on May 27, 2019 11:59:13 GMT -7
Hi all , I have a couple of questions about the Akrapovic link pipe. Just got my brand new mt10 with the Akrapovic end can but its not loud enough for me, If i have the link pipe fitted does the engine need remapping? Also how does it affect my warranty, i guess removing the cat might cause an issue???
Post by Deleted on May 28, 2019 9:56:04 GMT -7
If you remove the cat, engine would run dangerously lean, so you have to adjust fueling accordingly. And any ECU flash would irreversibly break an electronic seal (detectable by Yamaha via a download, but not by dealers), even if you remap back to stock, so I'd refrain from doing that during warranty. Your only option to avoid voiding your warranty would be a 'piggyback' device, like a Power Commander. I'd at least put a thousand miles on the bike before doing anything, just to make sure you don't have any issues. Good luck.
