kikenshika
Post by kikenshika on May 12, 2019 0:30:24 GMT -7
Hi guys! So I just got my bike shipped overseas and for some reason it's not able to start in first gear anymore with the clutch pulled in. The plunger switch seems to fine. Starts in neutral perfectly. Was wondering if anyone had any ideas? Thank you.
Post by RedAndBlack on May 12, 2019 2:37:17 GMT -7
Could be the clutch switch is bad but with the bike being rattled around during shipping, I would double and triple check all the switches and sensors and the cables, make sure nothing got knocked loose.
Post by clayton on May 12, 2019 7:12:09 GMT -7
Are you doing this with the kickstand down? If so it won’t start
kikenshika
Post by kikenshika on May 13, 2019 2:33:16 GMT -7
The kickstand is up when I try to start it.
Post by evitzee on May 13, 2019 7:03:54 GMT -7
Check all the interlock switches (sidestand, clutch) shown in the manual, one was damaged or knocked out of alignment in transit.
Post by thefinn on May 13, 2019 10:51:47 GMT -7
Check the clutch switch. If the kickstand switch was pernamently on, the bike would killswitch ktself whenever you put it in gear.
You might also want to check the cruise control disengage switches if they still work. Front brake, rear brake, clutch and turnig the throttle forward.
Post by Deleted on May 13, 2019 13:07:27 GMT -7
Our FZ/MT-10s don't require the clutch to start, so if you just can't start in gear, it absolutely has to be the clutch switch. Remember you have 2 switches there: one for the cruise cancel at the beginning of the travel, and an interlock one at the end of the travel, which has to be your issue. Check switch connections and continuity on the switch; hopefully one of those 2 things. Otherwise, the issue would be downstream from there, either on the wiring or ECU, which I really doubt. Good luck.
kikenshika
Post by kikenshika on May 14, 2019 19:05:52 GMT -7
Hi guys thanks for the feedback. I checked it out and I do believe it is the clutch switch. I think I'll just order a new one. Is this easy to replace or should I take it to a dealer?
kikenshika
Post by kikenshika on May 14, 2019 19:12:06 GMT -7
Was also thinking about taking apart the clutch switch just to check the inside cause everything outside seemed to be connected.
Post by RedAndBlack on May 15, 2019 13:35:10 GMT -7
I mean if you're going to buy a new one anyway, there's no harm in busting the old one open to make sure everythings connected.
But always check the alignment and play in everything first. I've had problems with kickstand/clutch/wheel sensors on every single bike I've owned. None have them have ever mechanically failed. They just need to be realigned, adjusted, or cleaned.
If your bike is still under warranty, yes, go take it back to Yamaha and get it serviced. It will be covered.
If you're not mechanically inclined, not on warranty, and your bike is due for service soon and you're going to have it serviced anyway, mention it to the mechanic. He might be able to figure out the problem really quickly and not even charge you for labor if it's just something simple like fixing the sensor alignment.
