squid4life
Post by squid4life on Mar 2, 2019 12:13:23 GMT -7
Looking to Sell my OEM rear rack, 125.00 shipped Conus. I can also be reached at lmp2227@gmail.com
nemecham
Post by nemecham on Mar 2, 2019 23:16:16 GMT -7
I may be interested... is it only compatible with the OEM top case or do they make adapters that allow you to use other aftermarket top cases?
Which top case did you use? Does it require any additional hardware to mount?
Thanks, Neil
nemecham
Post by nemecham on Mar 4, 2019 13:25:39 GMT -7
I may be interested... is it only compatible with the OEM top case or do they make adapters that allow you to use other aftermarket top cases? Which top case did you use? Does it require any additional hardware to mount? Thanks, Neil After some research, I decided to pass. This is a great deal if you are planning on getting the Yamaha brand top case. I think I am going to go with something that will give me a little more flexibility. GLWTS!
twistydave
Post by twistydave on Mar 9, 2019 13:37:20 GMT -7
I’ll take it
