kup0236
Post by kup0236 on Jan 19, 2019 17:05:03 GMT -7
Anyone know if FZ10 has a flasher? The troubleshooting tree doesn’t show one but my turn signals/hazards quit working and it’s annoying the crap out of me.
redgecko59
Flasher
Jan 19, 2019 17:21:49 GMT -7
Post by redgecko59 on Jan 19, 2019 17:21:49 GMT -7
I believe there is a fuse, have you checked that?
kup0236
Post by kup0236 on Jan 20, 2019 6:46:44 GMT -7
Yeah the fuse is fine. I get an indication on the dash when I hit the switch but no lights at the turn signals.
ghostrider1127
Flasher
Jan 20, 2019 7:57:48 GMT -7
Post by ghostrider1127 on Jan 20, 2019 7:57:48 GMT -7
No flasher , the module sit on Cluster unit
lastwish
Enter your message here...
Flasher
Jan 20, 2019 8:32:51 GMT -7
via mobile
Post by lastwish on Jan 20, 2019 8:32:51 GMT -7
I thought it had a flasher relay? I swear I saw some on ebay. And it's not in the left pseudo air scoop?
ghostrider1127
Flasher
Jan 20, 2019 11:59:33 GMT -7
Post by ghostrider1127 on Jan 20, 2019 11:59:33 GMT -7
Unluckily is different for the other MT family models.
Flasher
Jan 21, 2019 18:12:32 GMT -7
Post by Deleted on Jan 21, 2019 18:12:32 GMT -7
There has to be some kind of 'flasher' (probably solid state) somewhere, but what others are saying is it's integrated into the instrument cluster. Or the ECU. Did you install an electronic component? Or mess with the wiring? Seems weird that it failed all of a sudden for no reason. But if that's the case, make a warranty claim if you're still covered. Hopefully yes. Keep us posted, and good luck. Now I'm curious where exactly is it. He he.
kup0236
Post by kup0236 on Jan 22, 2019 10:43:54 GMT -7
Ok full story. I got my valves adjusted last year and while he had the bike I had my mechanic (not dealer) reflash the ecu. I already had a Graves flash and wanted to try a different flash. Bike ran fantastic but the turn signals and clock memory stopped working. He can’t figure out why and also I’ve talked to flash tune customer support. They also don’t know why. Both me and the mechanic went through the wiring. Everything seems fine except it doesn’t work. Lights on the dash work but not the signals. Weird.
kup0236
Post by kup0236 on Jan 22, 2019 11:53:01 GMT -7
No flasher , the module sit on Cluster unit Is it removable or would I have to replace the cluster?
ghostrider1127
Flasher
Jan 22, 2019 11:54:21 GMT -7
Post by ghostrider1127 on Jan 22, 2019 11:54:21 GMT -7
Can be repaired , but not removable like a standard relay.
Flasher
Jan 23, 2019 12:27:06 GMT -7
Post by Deleted on Jan 23, 2019 12:27:06 GMT -7
It's pretty obvious the last tune was the issue. But the better question is if whatever bad coding was fed into the ECU damaged something else. Your mechanic should make it right, but good luck with that. He he. I'd start by flashing the ECU back to stock, and see if that fixes the issue. If not, you better get a proper diagnosis before starting to throw money blindly at potential fixes. Good luck brother.
kup0236
Post by kup0236 on Jan 23, 2019 17:25:33 GMT -7
We already flashed the Ecu back to stock, back to the Graves flash and also back to stock again. Which is where it is now. I took it to A dealer because he said there was a recall flash from Yamaha but they couldn’t access my ECU. Still working with the mechanic he’s a good dude just busy.
bkvandy
Flasher
Nov 25, 2022 17:36:09 GMT -7
via mobile
Post by bkvandy on Nov 25, 2022 17:36:09 GMT -7
I have a 2017 fz10 that I bought. It had been in an accident and I'm fixing it up currently. It has after market turn signals and and integrated tail light. The left side indicators do not turn on and the indicator light for the left side does not appear either. However it does work for the right side. I've checked fuses, went through and cleaned up all the wiring(it didn't work before I worked on it), and I've checked the actual turn signal switch. The bike is flashed and I don't know by who. Could this be the issue. Like bad code or something?
Flasher
Nov 26, 2022 8:35:19 GMT -7
Post by mt10orc on Nov 26, 2022 8:35:19 GMT -7
I have a 2017 fz10 that I bought. It had been in an accident and I'm fixing it up currently. It has after market turn signals and and integrated tail light. The left side indicators do not turn on and the indicator light for the left side does not appear either. However it does work for the right side. I've checked fuses, went through and cleaned up all the wiring(it didn't work before I worked on it), and I've checked the actual turn signal switch. The bike is flashed and I don't know by who. Could this be the issue. Like bad code or something? It’s likely a wiring or component issue for your turn indicator. Sorry can’t be more specific, sounds like a relay or switch is not functioning.
