cassiofreitas
Post by cassiofreitas on Jan 13, 2019 8:47:13 GMT -7
Greetings,
I have a FZ-10 2017 which I have done some mods and now I'm highly interested to have the MT-10SP cluster installed on my FZ-10. I have been researching but I didn't find any thread/article/notes of anyone that already tried to get it done. Do you guys know if it's a direct swap? I know there is the Ohlins electronic suspension but as I'm not planning to have the ECU from MT-10SP no error code will be displayed (most like because errors came from ECU and FZ-10 ECU doesn't have built the error codes for Ohlins electronic suspension). And if you guys have info when I can buy an used one as I have searched on ebay by the part number BW8835000000 but I couldn't find anything perhaps there is another part number. Thanks
Cheers
Cassio Freitas
Post by parthz8 on May 31, 2021 15:05:55 GMT -7
Hi cassiofreitas- Did you replace MT10 meter B67835004000/B67835003000 with MT10 SP meter Assembly BW8835000000? Guys, anyone tried this before? MT10 meter assembly comes in two parts: Upper Assembly & Lower Assembly, while MT10 SP comes in single Assembly. Any thought or idea on this replacement?
Post by willl84 on Jun 1, 2021 7:19:58 GMT -7
AFAIK you can't do it, the ECU and wiring is different.
