superspirit
Post by superspirit on Jan 8, 2019 15:28:30 GMT -7
I'm really curious to see if the SW Motech bags work with that set up. I know they won't with the vagabond without a spacer to hold them out.
Post by thefinn on Jan 8, 2019 15:54:04 GMT -7
I'm really curious to see if the SW Motech bags work with that set up. I know they won't with the vagabond without a spacer to hold them out. Ill make a new thread for them (and modifications if required) when I get them
Post by Deleted on Jan 11, 2019 14:28:51 GMT -7
The cheap tail tidy I got from ebay in the uk for £25 fits on the bottom of the standard tail tidy arm which means it retains the key cover and cable tunking. The Vagabond I bought also retains it. The only issue is you have to cut a piece of it, but you can't see that at all. Looks like a factory fit piece, but it's obviously not OEM due to the lack of big a$$ fender . Hey Finn, thanks for your offer to help with the Blaze bags. Curious about your turn-signal max width measurement; I'm sure it's less than mine. But they seem located about the same lengthwise. Looking forward to your review . Thanks.
Post by Deleted on Jan 11, 2019 16:47:25 GMT -7
I'm really curious to see if the SW Motech bags work with that set up. I know they won't with the vagabond without a spacer to hold them out.Hope you're wrong. Ha ha. But if that's the case, the solution could be to modify the chromed tubes (squared where they go into the bracket) somehow, IMO. Either by trying to bend them out a little at the back, or heating them with a torch to re-bend them into the ideal form (bags sticking out less at the front too). But let's hope we hear good news from Finn . Have a great weekend gang.
Post by thefinn on Jan 12, 2019 8:21:57 GMT -7
Might take a while before I get my review in. Got some unexpected extra work on my hands. Best case I get them on and a review out at the end of January/beginning of February, worst case in the beginning of March.
