latte
Post by latte on Jan 1, 2019 16:42:37 GMT -7
Post by Deleted on Jan 2, 2019 12:00:23 GMT -7
Great price, but my guess is the front ones should not require (nor have the space for) that long relay. Only one relay is needed per side on cars, so it shouldn't be any different on bikes. Just saying this because you mentioned 'should fit on any position'. To avoid any issues, I'd either research the service manual, or clearly state front fitment is at your own risk . The front signals are the most vulnerable to be damaged on a spill, so the most likely reason why somebody might want them. Good luck with the sale brother.
steves
Post by steves on Jan 26, 2019 21:48:11 GMT -7
Is the turn signal you're selling from the left (B67-83330-10-00) or right (B67-83340-10-00) side? Yamaha has the part numbers I put in parentheses, so I presume they're different.
I need a right rear turn signal.
redgecko59
Post by redgecko59 on Jan 27, 2019 6:12:18 GMT -7
Is the turn signal you're selling from the left (B67-83330-10-00) or right (B67-83340-10-00) side? Yamaha has the part numbers I put in parentheses, so I presume they're different. I need a right rear turn signal. Should be no difference in the signal, part number difference is probably for the color of wiring and plug as they are different. Should be able to use it no problem just put your own label so you know which is which for future reference.
Post by thefinn on Jan 27, 2019 9:45:46 GMT -7
Im pretty sure its only for the rear, I accidentally kicked the OEM rear indicator off and the front indicator started to blink fas as a result, like LED blinkers do without a relay.
steves
Post by steves on Jan 27, 2019 17:19:39 GMT -7
Is the turn signal you're selling from the left (B67-83330-10-00) or right (B67-83340-10-00) side? Yamaha has the part numbers I put in parentheses, so I presume they're different. I need a right rear turn signal. Should be no difference in the signal, part number difference is probably for the color of wiring and plug as they are different. Should be able to use it no problem just put your own label so you know which is which for future reference. OK, then I'll take it. Please send me a PM and I'll send PayPal and my address.
godameda
Post by godameda on Feb 12, 2019 8:52:09 GMT -7
Is the turn signal still for sale? If so, I'll buy it.
