zachsfz
Post by zachsfz on Dec 23, 2018 21:57:24 GMT -7
ghostrider1127
Post by ghostrider1127 on Dec 24, 2018 1:57:28 GMT -7
You can fit a decat (plenty of models- brand - material -shape) and with the oem can will be LOUD , but my suggestion is to get also a reflash ; you can switch off the servo motor and the AIS .
Post by heathhudnall on Dec 24, 2018 5:47:38 GMT -7
You chose the fastest color!
Post by evitzee on Dec 24, 2018 8:03:10 GMT -7
If you remove the cat you should do a reflash. But you will still have a very loud, and obnoxious, sounding machine because noise control is done in the cat. Personally I don't understand why riders want a loud bike that annoys everyone. Once you put earplugs in, helmet on and get above 50 mph the engine clatter and wind noise will mostly mask the exhaust sound.
There are plenty of threads of people de-catting, some positive, some negative. Read up and make your decision.
Post by Deleted on Dec 25, 2018 1:08:11 GMT -7
Personally I don't understand why riders want a loud bike that annoys everyone. Me neither. But not only that. Without a cat, the fuel smell is awful, and you need to wash your riding clothes after every ride. And yes, you're also polluting waaaaay more, so worth mentioning. He he. Oh, and no, with the bike that loud, it's really bothersome at higher rpm, even with earplugs and wind noise. Super annoying. My stock bike with the Graves slip-on is borderline loud; no need for more than a slip-on IMO. OP, the OEM can is straight-thru. If you decat, it's stupid loud man. You really need an aftermarket muffler with a baffle to avoid being hassled by the law, your SO, and neighbors. Many owners have gone back to quieter systems; do some research. We have enough of that with Harleys. Ha ha. Good luck anyway.
zachsfz
Post by zachsfz on Dec 25, 2018 12:03:11 GMT -7
Thanks for all the input. Its all good info. If I were to just invest into a slip on with the cat will it maybe change the tone at all or is there lttle to no difference. Also if i were to keep the stock can off and just by a tip (for a more finished look) would it be hurting anything internally on the bike.
Post by Deleted on Dec 25, 2018 12:45:15 GMT -7
The Graves slip-on on my bike made a dramatic difference from stock. It sounds incredible. Very deep, loud enough, and refined. At around 3K rpm, while just tooling around, it sounds like a muscle bike. Remember the stock can is straight-thru and not tapered at all, so from no can to any can is not going to make a difference in fueling. Many folks here have installed just tips; search for those threads. But they sound raspy to me, and I don't like that. The stock can doesn't have a nice sound to it either, at least to me. And doesn't look nice either. What I liked about mine (pictured below) is you can remove the decal before installation, and it looks OEM, since it doesn't have springs or a band, and has OEM fit and finish. That's exactly what I wanted. If I were you, since you might like a louder exhaust than mine, I'd probably buy the Yoshi Alpha (which comes with a baffle), remove the baffle, and it should sound very similar to mine, which is deep and refined. If you don't think it's loud enough, then you can add a decat pipe (or a smaller cat) and install the baffle and you should be good to go. Good luck.
Post by evitzee on Dec 25, 2018 13:09:12 GMT -7
I have the Yosh Alpha T and huge improvement over stock. A little louder but much more depth in tone and personality. I've not tried it with the battle which isn't needed imo. 10 min installation, typical Yosh quality.
Post by clayton on Dec 25, 2018 13:56:43 GMT -7
Luv my 3/4 Alfa T system. Warn u it’s very loud! Sound is so awesome!
ghostrider1127
Post by ghostrider1127 on Dec 26, 2018 1:17:47 GMT -7
Remember the stock can is straight-thru and not tapered at all, so from no can to any can is not going to make a difference in fueling. Even with another can fueling will be alterate , not need to reflash sure . Heard lot of time this conviction
Post by Deleted on Dec 26, 2018 23:30:03 GMT -7
I have the Yosh Alpha T and huge improvement over stock. A little louder but much more depth in tone and personality. I've not tried it with the battle which isn't needed imo. As I mentioned, you only need the baffle if you decat. Stock would be too tame with the baffle indeed. I suggested that system because it comes with a baffle, so he doesn't have to get a different exhaust if he wants more noise. Mine is the most stock looking (without decal), but has no baffle, so didn't recommend it to him. Yoshi is the only other I'd have considered if Graves didn't exist, due to also having a proper bracket and clamp (bands and springs look cheap to me). All others have one or both.
Post by evitzee on Dec 27, 2018 4:58:05 GMT -7
Yeah, but I don't think the baffle will come close to compensating for a decatted system. It's still gonna be loud.
Post by Deleted on Dec 27, 2018 12:10:33 GMT -7
You're absolutely correct. The FZ/MT-10 doesn't even sound nice that freaking loud and raspy IMO. But at least the volume would go down from stupid loud to obnoxiously loud with a baffle. Ha ha.
exuptoy
Post by exuptoy on Dec 28, 2018 1:58:27 GMT -7
You're absolutely correct. The FZ/MT-10 doesn't even sound nice that freaking loud and raspy IMO. But at least the volume would go down from stupid loud to obnoxiously loud with a baffle. Ha ha. In my opinion, thats spot on, hence my purchasing the Leo Vince baffled decat, so I also purchased a baffle from Scorpion for the RP1-GP but all that consisted of was a piece of tube about 2-3 inches long. They reckoned that any longer robs the MT10 of power and this supposedly reduces the noise by 1.5-2db. I reckon they're full of shit as the audible difference is so hard to detect! The Leo makes a difference compared to the standard decat though.
Post by mt10orc on May 13, 2022 17:11:23 GMT -7
Good discussion have a Leo Vince mid pipe which I’ll be installing soon and Graves slip on which is currently installed. Let me just say it sounds good at high RPMs but want a bit more. Curious if anyone has this setup and what it sounds like?
I’ll be getting the FTEcu bench harness and 2 Wheel Dyno Work flash for this setup soon. Will do the delete when I have all the goodies. Hope I can contain myself before I get the tune.
